Maybe some one have virgin or not virgin dump from the front bcm module (DX23-14B476-BG)?
Can't read eeprom nor d-flash. Car wont start and saying no key found.
Is it possible to restore it if i read the rear bcm?
bloody hell am in the same boat? just disconnected the negative termianl? and all these problems? dx2314b476ag thats my part number for front bcm ? any dumps would be appricated?
Both batteries gone. I have dump gor your number, ill send you in the evening. Trying to resolve the ptoblem using the rear bcm.
thanks waiting for dumps? when u mean use rear bcm should i get the eeprom and dflash from the rear bcm and use that on the front bcm?
Problem solved Used just rear eeprom not d flash and thing like 1 hour with JLR SDD updating security modules and programming new keys and it starts.
Here is the dump for your part number, found in the net when looking for a dump. Dont know if it helps you but you can try.
adil_007 (1st August, 2020), antonypaul (26th September, 2024), atakan (4th December, 2023), AutoWOW (22nd May, 2023), BusCan (29th March, 2024), datapage (25th June, 2022), electromech (14th September, 2024), fred77 (5th October, 2020), Hayssam1 (25th June, 2021), jarecki55 (26th February, 2020), Landetos (14th March, 2023), lokher (26th April, 2022), mkopytekchi89 (30th June, 2022), moca (10th December, 2022), radion360 (12th December, 2023), talk2idris (26th November, 2022), v-diag (17th September, 2019), vanos batam (28th March, 2023), zar0079 (14th February, 2020)
thanks already have this will try the rear bcm eeprom?
Any progress?
Going to test later today contacted the guy who's files you have posted he said just us the eprom and p-flash from his files and code the keys? also have taken the eeprom from the rear bcm, so will try both option?
will let you know the outcome. thanks
Today tried that eprom. Every thing worked except front whipers and module id error but disconected the battery and same, no key found.
If im right that dump is from a sedan. I manage to everything work except the rear window wiper and the washer pump. So im looking for dump from a 5 door car. Will be grateful if some one can share.
Contact me. If washer pump is not working it means your bcm is still faulty. if you disconnect the battery, it will lost keys again. I have 100% working recovery solution.
antonypaul (26th September, 2024), ecumix (2nd March, 2022), lokher (26th April, 2022), Rito (26th July, 2023), vasa (31st January, 2020)
hi, DX23_14B476_AG jaguar bcm as you 0n0t0le post you got it fix ,i try to do some work on it but still cant make it fully working(central lock work on key but no ignition authorized),i wonder if you can have look it guys or give some hints?
gerardo1 (15th April, 2023)
