Results 1 to 15 of 21
    DiReCtX's Avatar
    Default Fiat Tipo ME17.3.0 virgin
    Hello
    Did anyone manage to virgin this ecu ??
    I suppose the code is in four places starting with C2FC0100... at
    0xC600
    0xC680
    0xC800
    0xC880
    Can anyone confirm that the location is correct ??
  2. The Following User Says Thank You to DiReCtX For This Useful Post:
    Necto (29th June, 2020)
  3. #2
    hello, solve for virgin?? i have same problem for one ecu abarth.....
    Sep 2019
    good work man
  5. The Following 8 Users Say Thank You to vladimir88 For This Useful Post:
    Alonet (30th December, 2021), danielif (11th December, 2020), DiReCtX (26th March, 2020), marcobh5 (13th December, 2020), Necto (29th June, 2020), sazimam11 (10th April, 2025), scudi1 (21st January, 2021), Stelaras26 (19th June, 2023)
  6. #4
    Sep 2019
    you need cable kkl
  7. The Following 5 Users Say Thank You to vladimir88 For This Useful Post:
    DiReCtX (26th March, 2020), marcobh5 (13th December, 2020), pinotec (21st August, 2020), sazimam11 (10th April, 2025), scudi1 (21st January, 2021)
  8. #5
    hello..... where is virgin dump for write?? i view only program
  9. #6
    DiReCtX's Avatar
    Quote Originally Posted by rego88 View Post
    You need use program from vladimir88 and kkl cable to read eeprom from ecu and virgin them.
  10. #7
    Quote Originally Posted by DiReCtX View Post
    i view all, but the program not in english and the pc don t support a lenguage, i don t understand..... i have kkl cable, adapter, and all.... i try..... arrive 100% and write an script.... but is impossible read..... i try into a car and not start.....
  11. #8
    DiReCtX's Avatar
    @vladimir88 you can suggest or provide some instructions on how to do this program virgin, because the program is in Russian and it's hard to confess with it, this program can do me17.3.0 ??
    Thanks in advance
  12. #9
    Jun 2020
    Great! Thank you very much!
  13. #10
    Jun 2020
    Can`t download files. How many posts I must send ?
  14. #11
    Jun 2020
    Upper knob is "Flash", than "Clean" and choose port
  15. #12
    Sep 2019
  16. The Following User Says Thank You to vladimir88 For This Useful Post:
    danielif (1st November, 2021)
  17. #13
    Sep 2019
    ktm bench red write this ecu not need open
  18. #14
    DiReCtX's Avatar
    iskcode is in block C2FC01, I have virgin state this block and all d-flash from new ecu me17.3.0 from "factory", now I must test used ecu.
  19. #15
    Aug 2018
    DiReCtX did you manage to verginize ecu through manually modify the lines in your first post?
