Results 1 to 5 of 5
    Codekuba's Avatar
    Aug 2018
    Default Corvette 2014 year c7 all keys lost
    I Have chevrolet corvette
    2014 year
    Model C7
    Cabrio
    Engine 6.2 V8
    All keys lost
    Please help
    Via obd? Vvdi2?
    HELP == thanks + reputation
    Jun 2013
    Its about 16:00 in New York now. And 13:00 in California.
    So the US members, should be able to help you out.
    Is it Prox with 24c32 ?
    alex_r_2001's Avatar
    New Jersey ,, USA
    If you have passthru with acdelcotds subscription I know 100% programming possible... 24 month access pass for 1 vin number is $40.00... Maybe other tools can do but I have never programmed that particular vehicle... No need to know pin number because acdelcotds has pin codes integrated into Java Interface... Only need pin number when swapping modules... Global A Architectural
    Jan 2017
    USA ����
    from usa?
    you can do by on board programming
    pretty much click tailgate cylinder under car 5 times with metal key and do ten minutes x3 introducing new remote
    C7 RKE Transmitter Programming
    InstructionsBefore you begin programming, read the entire instruction procedure thoroughly.
    Also: Aftermarket radios can cause an issue when you try to get into theprogramming mode. The radio triggers a code that the radio security feature is nottalking to the ECM properly. If you have an aftermarket radio and did not buy theharness for the door beeps and OnStar, you might NOT be able to get intoprogramming mode.
    Also: Model Year 2017 and newer require 2 FOBs to do the short program to addFOB #3. If you DO NOT have both FOBs and want to add a new FOB to have 2FOBs, you must do the long program and get FOBs 1 & 2.
    Also: Canadian Spec cars can do the short programming procedure but must have the dealer perform the long programming procedure.
    Also: European Spec cars cannot do the short or long procedure. All remote programming must be done by the dealer.
    Also: This can be a long time “on battery”, it may be a good idea to hook a batterytender up to the car during programming to insure that you don’t discharge thebattery to where the programming fails or the car won’t start.
    go here for more
    https://www.ls2.com/boggs/c7/C7RKEProgramming.pdf
    your welcome
  5. The Following User Says Thank You to sleepyrz For This Useful Post:
    Weasel3 (22nd September, 2019)
    Sep 2016
    Rear driver side(deacription of location from other forum) is bcm like on insignia or astra j. Read with programmer and do key with tango or use ioterminal or smok to read via obd2.
  7. The Following 2 Users Say Thank You to qeso705 For This Useful Post:
    p1et (27th September, 2019), Weasel3 (22nd September, 2019)
