Page 1 of 3 123 LastLast
Results 1 to 15 of 39
    Mar 2019
    Earth
    Default ASTRA H CIM REPAIR GUIDE
    HI Guys.If someone of you is facing problems with the cim module of Astra H ( the horn doesn t work or it s working only with dimmed lights,it doesn recognize the transponder,or the steering wheel controls) this tutorial will help you to fix it lifetime waranty.Pass in pm after thanks and rep .
  2. The Following 91 Users Say Thank You to 12manux For This Useful Post:
    AAKEYS (11th August, 2022), adrianojeminaj9 (15th April, 2020), adrianoo (11th April, 2023), AlexSrz (29th March, 2024), amaflo (16th December, 2019), andy99 (2nd April, 2020), ardeeboy1502 (21st March, 2020), autoelektrika20 (9th March, 2025), badyl00 (20th June, 2024), barcu (1st October, 2019), bocaje (23rd September, 2019), bsdady (26th September, 2019), buul (8th February, 2023), Cesarec (13th December, 2023), coco81 (18th November, 2023), cristovao (19th February, 2022), d.zio (4th April, 2020), d33j (15th April, 2025), daniersms (21st September, 2019), dEONBE (16th April, 2020), desapna11 (26th January, 2020), deseak54 (27th January, 2024), dimisx1 (1st February, 2024), dragon100 (27th February, 2022), Elektron1 (8th December, 2019), enpon (15th July, 2023), erqa (29th April, 2023), ersin (7th August, 2024), florin_leo (2nd January, 2020), garracuca (11th August, 2022), geneticar (17th October, 2019), Il Tulipano Nero (1st November, 2022), issam216 (29th August, 2022), ivanmihov (5th October, 2019), i_shot_the_sheriff (9th October, 2019), janusz21 (8th October, 2019), javiercj (11th August, 2022), jmorek (3rd August, 2024), jolor (1st December, 2019), Josue (7th August, 2024), kadett90 (5th October, 2019), keyhacker (3rd April, 2020), kikay (15th December, 2023), koranx (24th April, 2023), kyawkyaw (14th August, 2024), leonel (24th November, 2023), Lightning (19th September, 2024), line44 (6th April, 2020), marioDem (30th May, 2024), mark1313 (18th November, 2023), max70 (21st September, 2019), maxim57 (29th January, 2023), mercmedics (6th November, 2022), mikajna (29th March, 2020), MNenad (28th October, 2019), morgano (2nd January, 2020), mps125 (25th February, 2020), opel91025 (23rd June, 2021), pawelelek22 (29th October, 2023), penio87 (8th June, 2021), Pistonazo (8th January, 2020), Popotecnica (23rd September, 2019), pupik5492 (1st December, 2019), R1rf23 (12th September, 2023), Ray6K (11th October, 2022), Robalowy (19th March, 2023), SALAS (22nd April, 2020), sefakrmzrk (4th April, 2023), Shawsy67 (2nd March, 2020), SimonSnt (25th December, 2019), slawomir (17th February, 2022), sonikx (13th April, 2020), spens (4th August, 2021), Spike2777 (2nd November, 2022), stanislav georgiev (18th December, 2019), Stelaras26 (28th December, 2023), stevieg68 (23rd February, 2023), Swist (15th April, 2023), Tagne (11th September, 2024), thor3121 (23rd November, 2023), Tobby_35 (2nd April, 2023), Turbosider (19th November, 2024), vb77 (28th September, 2024), vvanka7a (23rd March, 2022), YASS59 (5th January, 2020)
  3. #2
    Feb 2016
    hi,manux can you send me the pasword to open atachments
  4. The Following User Says Thank You to artpas For This Useful Post:
  5. #3
    kadett90's Avatar
    Mar 2017
    Pass please.
  6. The Following User Says Thank You to kadett90 For This Useful Post:
  7. #4
    Mar 2012
  8. The Following 4 Users Say Thank You to zwarder For This Useful Post:
    Donabe (17th March, 2021), MOBILTRONIC (25th April, 2020), SauliusS (13th April, 2023), YASS59 (5th January, 2020)
  9. #5
    Mar 2019
    Earth
    something like that
  10. The Following User Says Thank You to 12manux For This Useful Post:
  11. #6
    Sep 2018
    Austria
    Does it has anything to do with these faults:
    B3925-instrument, wrong environment indentifer received, permanent
    U2111-Eps, no communication, permanent
  12. The Following User Says Thank You to caja88 For This Useful Post:
  13. #7
    Jun 2013
    Kikinda Serbia
    Something I don't quite understand why people set passwords on their attachments?
    If you do not want them to be reviewed, write that you have a solution and if someone needs you, let them know in a private message. This is like I have something but I don't tell you ..... I don't see the purpose.
    With these Cim modules, we have a problem with the connector contacts. Connectors can be opened and pins squeezed to have contact, the problem will probably re-occur over time. One solution is to solder wires instead of connectors but only if you fix on your car that you no longer have a problem ..... Still the master has to work so this should not be done
    When there is a bigger problem than with any SMD electronics. It has to be refracted with quality flux .....
    I don't have any pictures at the moment but as soon as I have the opportunity I will post them publicly for all to see
  14. The Following 2 Users Say Thank You to RadovanPetkovic For This Useful Post:
    Kranjac (27th January, 2024), line44 (6th April, 2020)
  15. #8
    Mar 2019
    Earth
    I automatically send password in pm ,after i get thank at my post.Easy as that.It s an easy job to repair it,i can say the easiest job.But if i can help someone ,why not.
  16. The Following 3 Users Say Thank You to 12manux For This Useful Post:
    catastefan (28th December, 2019), line44 (7th July, 2020), mexanico1971 (13th April, 2020)
  17. #9
    Aug 2014
    Thanks for sharing
    Plase send me password.
    Thanks anticipated!
  18. #10
    GB
    CIM ASTRA H REPAIR GUIDE.rar
    Pass please.Thanks.
  19. The Following User Says Thank You to florin_leo For This Useful Post:
  20. #11
    Nov 2015
    Pass please
  21. #12
    Jul 2019
    Hi could you send password please.
  22. #13
    Jun 2019
    Quote Originally Posted by zwarder View Post
    Is it something else than this?
  23. #14
    Mar 2019
    Earth
    Pretty much the same
  24. #15
    Jun 2016
    SALVE PASS PER FAVORE E GRAZIE
