Results 1 to 14 of 14
    Jan 2018
    Default i need solution truck isuzu npr dash hours
    HELLO
    help me to change cluster truck isuzu npr 93c86 1549.8hours 47956 km mielage to 1000 km 10 hours
    thanks for your help
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    mileage is easy to change, algorithm is Kansei, same as Nissan Terrano for example.
    Hours?, that's new for me.
    Jan 2018
    hello is truck isuzu npr 2018 with hours see the picture and thanks
    Sep 2013
    I need other file to know where is hours located, then i can use my Brain.exe
    Dr. Zoidberg's Avatar
    Oct 2015
    Talca-Chile.
    If you like, try this
    test.rar
    Jan 2018
    thanks Dr. Zoidberg you adjute just the km but i need solution to adjute the hours
    Sep 2013
    Maybe If you drive some hours, then you post new file here to compare them and to see what happens
  8. The Following User Says Thank You to jomberykaso For This Useful Post:
    Dr. Zoidberg (24th September, 2019)
    Jan 2018
    hello what about calibrate hours the truck isuzu npr 93c86 you find the solution
  10. #9
    Sep 2013
    You need to find the solution, we don't.
    You need to post file original with some more hours. Then we could help you
  11. #10
    Jan 2018
    hello this is new file cluster truck isuzu npr 93c86 1606.3 hours 51028 km
    millage to 1000 km 10 hours and thanks
  12. #11
    Jan 2018
    plz can someone help me to find solution the hours nissan npr 93c86
  13. #12
    afitijuana's Avatar
    Hi Newbie, info is store in engine computer went they go to shop will read from there
    https://www.youtube.com/watch?v=ItnjqIhmEhg
  14. #13
    Sep 2013
    Report.....pass in Private message
  15. #14
    Mar 2025
    Default change hours isuzu cluster
    HI, need change isuzu work hours in cluster
    old mileage 38182 mi.
    old hours 8330.9
    new mileage 38182 mi.
    new hours 1600
