Results 1 to 5 of 5
    Sep 2019
    Europe
    Default Simos 8.51 bricked
    Hello.
    Had a bad luck today when tried to flash 2013 A6 3.0TFSI 228kw with CMD.
    Dont know if ECU been flashed previously, did read from CMD server. Tried to write tuned file when at the end of writing cmd showed "void11" and then "OK".
    Engine does not start, fans spinning full speed, other modules have no communication with ECU, cant do "back to stock" or write original file. KTAG does not have any solution for this ecu.
    Anyone had same issues with simos 8.5. I believe there is no hope to recover this ecu, so question is what equipment and works required to adapt other ecu? What could cause this problem and how to escape this next time?
    Thanks.
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Try to to write ori sgo by Odis e or vcp...
    Sep 2019
    Europe
    no connection with ecu via vcp. tried.
    figani's Avatar
    Feb 2018
    Quote Originally Posted by Dooba View Post
    Hello.
    Thanks.
    post SW Version and upload your ori file from CMD Server....
    Calgary
    Got same issue.... bricked 8.51 with cmd but it read fine and sent VR file.......
    Any solution?
    Also I tried KTAG and didnot work....
    BMW Fan - Ecu remapper - Canada
