Zafira C year 2012 (range 2011-2019)
Engine 1.6 ECU LWC1/6L
Petrol with small tank and CNG.
My mechanic did timing belt 1 month ago, 4 new spark plug, coil has been replaced july 2018.
Owner said runs bad only with CNG.
Did a scan and got 2 DTC:
* Misfire cylinder 2
* Multiple random misfire
With that said and previous history, we got no time to test the car
and decided to buy 4 rebuilt CNG injectors.
CNG injectors fitted then we tested the car in street and found
that Owner is a liar:
- car runs bad with petrol
- now car runs really bad with CNG
Did a scan with BrainBee and got 3 DTC:
P0103 MAF high frequency circuit sensor
P2279 Heated lambda signal locked on rich (level2 sensor2)
P0079 Low voltage Circuit intake air temperature sensor
Did a scan with Actia and got 3 DTC:
P2279 Absolute pressure - turbocharger pressure
P0079 Circuit 2 Intake air temperature sensor (low voltage)
Let's start with P2279 that has two meaning, one for BrainBee and other for Actia.
So I checked with Actia and the voltage of the second lambda
is stock to 0.455 V with car at 0 mph with engine off,
engine at idle, engine accelerated, engine cold, engine hot.
Then I checked with BrainBee and the voltage of the second lambda
is stock to 0.641 V with car at 0 mph and engine hot.
Then P0103 with BrainBee, engine hot at idle I have:
Air mass frequency is 1953 Hz engine running with CNG
Air flow 2.88 g/s engine running bad at idle with CNG
Air mass frequency is 1904 Hz engine running with petrol
Air flow 1.41 g/s engine running better at idle with petrol
Is it normal air mass frequency 1900 Hz at idle?
Is it normal Air flow that is twice running on CNG with respect to petrol?
Other readings that I should report?
Then P0079 Circuit 2 Intake air temperature sensor (low voltage)
With engine hot I read 51 Celsius degree with car at 0 mph at idle
and after a run I read 38 Celsius degree with car at 0 mph at idle
There are two sensors in intake manifold, which one is air temperature sensor?
Left or right?
I've found oil in the thread of spark plug number 2
but I did a scan and the cylinder that is misfiring is another one:
BrainBee reads 16 misfire on cylinder 3 during a 20 minutes trip.
Another mechanic took the car and get 100 misfire on cylinder 3.
Tomorrow I will exchange the position of CNG injectors.
