Results 1 to 15 of 16
    Jun 2019
    Question Mileage Correction Tool recommendation
    Hello guys,
    I was looking for information about what the best mileage correction tools are because I want it to cover more car models as possible and possibly not above $500.
    The best I found for its price was Digiprog III V4.94 Odometer correction . Have someone used it?
    I have two question tho:
    Do some car dashboards need desoldering at some point because a guy told me that the most of the cars do.
    Adjusting mileage using OBD2 doesn't require you to take off the dashboard, right? Because I tried on Ford Transit 2007 with Autel Maxicom MK808 and it was unsuccessful.
    Any recommendations?
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by Codelove View Post
    Hello guys,
    Here you'll find the most things about digiprog...
    https://www.digital-kaos.co.uk/forum...ns-and-answers
  3. The Following User Says Thank You to figani For This Useful Post:
    Codelove (6th October, 2019)
    galaxy0634's Avatar
    Jan 2018
    Namek planet
    Obd only vw audi. Skoda seat and there is citroen jumper and peugeot boxer with obd to but like renault GM and.... You need to desoldring the eeprom
    *I helped*push thanks button
  5. The Following 2 Users Say Thank You to galaxy0634 For This Useful Post:
    Codelove (6th October, 2019), Russlander (7th October, 2019)
  6. #4
    Jun 2019
    Thanks for your answers guys!
    I think I will buy digiprog 3 since it looks more complete with all those cables and OBD + EEPROM.
    However, let's say a car is not supported. Will I be able to read at least EEPROM, so I can later try to edit its hex manually?
    figani's Avatar
    Feb 2018
    yes, but not each digiprog is usb able...
    when you order it check that it has a ftdi chip...
    you can solder it alone later...
    but price is almost same...
    that you can connect it on pc/notebook...
    transfer eeprom...
    tool has an editor, but on pc youŽll be able better to handle it...
    and or upload it in forum...
  8. The Following 2 Users Say Thank You to figani For This Useful Post:
    BMWE46 (27th February, 2020), Codelove (6th October, 2019)
  9. #6
    Jun 2019
    Quote Originally Posted by figani View Post
    transfer eeprom...
    Thanks! That's what I wanted to know.
    https://www.aliexpress.com/item/3300...chweb201603_52
    Which package do you recommend me to buy? Are all those cables useful? Because I think only the last package includes both OBD and FTDI but not the cables.
    Not sure if "EU normal: full" package includes both OBD and FTDI.
  10. #7
    figani's Avatar
    Feb 2018
    on this site EU FULL Norml stays 139$...
    and EU FULL FTDI stays 141$...
    the second one with FTDI you can connect with usb cable...
  11. The Following User Says Thank You to figani For This Useful Post:
  12. #8
    Jun 2019
    Then, it will be the one for $141.68. I just didn't understand if the FTDI chip supports OBD2 port. Like it is able to be connected with USB and OBD2 too?
  13. #9
    figani's Avatar
    Feb 2018
    obd is for connecting on car...
    when the tool has a ftdi chip you can connect the tool with your usb port pn pc/laptop...
  14. #10
    Jun 2019
    No no, you didn't get me.
    I know OBD's meaning. What I'm confused for is can the FTDI chip ($141.68 package) be connected to OBD port too? I understand that it can be connected to USB but can it be connected on the OBD port as well? There are too many cables on the picture and it's hard to distinguish them, that's why I'm confused.
  15. #11
    FTDI if yes on the board working only with usb.
    All of china digiprog working by OBD and always if you buy full cables with digi you will connect by obd if possible, if not by cluster plug if not by clips.
    And that's why there are so many cables.
  16. The Following User Says Thank You to bodzio012 For This Useful Post:
  17. #12
    Jun 2019
    Quote Originally Posted by bodzio012 View Post
    Big thanks buddy, I ordered it.
  18. #13
    Jun 2019
    It arrived, I tested it with OBD and it worked fine. However, I don't see any USB cable there, even tho it's the FTDI chip. How do I connect it to PC?
  19. #14
    figani's Avatar
    Feb 2018
    Use USB cable...
    Like printer cable...
  20. The Following User Says Thank You to figani For This Useful Post:
    Codelove (14th October, 2019)
  21. #15
    Dec 2010
    If you start bussnes you need to buy
    original good programer.
    90% of the car will cover dp4
    then you need 2nd device
    if you in usa you need dsp3 or jprog7 the best one for Usa cars.
    for hundai kia honda toyota fujitsu
    and S6J3001 processor you will need iprog pro and script.
    for cas 2 3 3+ and ezs you need rosfar
    but they dont seel them any more you can buy cas3 programer
    on ebay red one.
    then you will need diagnostic autell or similar.
    and after this you can start bussnes
    not to do cars for $50-60
    but take right money for your job.
    good luck in your bussines.
  22. The Following 4 Users Say Thank You to rukartinatv For This Useful Post:
    BMWE46 (27th February, 2020), Codelove (14th October, 2019), lexidime (27th October, 2019), mann357 (15th October, 2019)
