Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 59
  1. #16
    Portugal
    Quote Originally Posted by GT-INFO View Post
    probably not mcu becouse my MCU is R5F61544 so this is different group mcu ... one group example NEC i understand but next different mcu the same? dont think so ..probelm is probably connections or components bad
    In Fiat I've read in a forum (https://forums.outandaboutlive.co.uk...Problem/45806/) that with a SW revision the problem is solved. Your MCU will have to be programed the same as mine for the warning lights to appear in a correct way! I think it will be so.
  2. #17
    marcolr's Avatar
    Quote Originally Posted by JotaB View Post
    And where you find the file to program the mcu?
    If my post was helpful press Thanks button!!
  3. #18
    Meat-Head's Avatar
    Find. Working set and leech it
  4. The Following User Says Thank You to Meat-Head For This Useful Post:
    marcolr (22nd January, 2020)
  5. #19
    Portugal
    Quote Originally Posted by marcolr View Post
    That's the one million dollar question
    BR
  6. #20
    Portugal
    Yes maybe like that. But used ones are expensive.
    You'll FIND the knives and forks in the left-handdrawer.
    Or maybe like this. Who knows!!!
  7. #21
    Meat-Head's Avatar
    Find a set with more miles than a spaceship on them, as long as they work
  8. The Following User Says Thank You to Meat-Head For This Useful Post:
    Stelaras26 (12th March, 2020)
  9. #22
    Meat-Head's Avatar
  10. #23
    migmig85's Avatar
    Jan 2018
    Has anyone solved this problem ?
    If i can help you, press THANKS + REP !!!
    If you don't helping because like, only for money !!!
    Don't write in my thread !!!
  11. #24
    Meat-Head's Avatar
    Ok guys i admit, been looking at INFERIOR so called “websites” and dug some useful
    information up.
    i have washed my hands and hair, wiped my boots etc
    CAUTION CONTAINS ADVERTISING
    INFERIOR SITE
    Cartronix repairs were discussed in this recent-ish forum thread relating to an X250 Peugeot Boxer’s problematical instrument-cluster.
    {INFERIOR LINK REMOVED}
    It will be noted that Cartronix had two ‘goes’ at fixing the problem, initially replacing the cluster’s display and processor, then replacing another ‘electronic component’. After the 2nd repair the cluster worked for 6 weeks, then died, then recovered. A Peugeot agent subsequently found some loose connections (which may have been the cause of the problem to begin with).
    The fault described in that thread appears to differ from the well-known ‘dim/spurious warning lights’ issue that is mentioned on this Cartronox webpage
    https://cartronix.co.uk/product/fiat...r-dash-repair/
    You’ll see that Cartronix say "We replace the faulty parts with new more robust components
  12. The Following User Says Thank You to Meat-Head For This Useful Post:
    marcolr (5th February, 2020)
  13. #25
    Meat-Head's Avatar
    CAUTION ADVERTISEMENT
    ok, the way video shown could be a false representation, near to mcu checks
    with meter 2 components, then remove one, yet another’s video is just the lcd on its own
    https://m.youtube.com/watch?v=S1Y1-MX1bEk
  14. The Following User Says Thank You to Meat-Head For This Useful Post:
  15. #26
    Meat-Head's Avatar
    Uppage:-
    just rung really nice man at “a k speedo” had a talk about this thread
    he is going to join this fantastic forum we have and see if we can get to bottom of it.
    Remember therez other threads on this subject linked in above posts
  16. #27
    italy
    i've the solution for this problem.
    problem it's some led are defective.
    some led not work pefectly as a diode and negative or positive can pass trought diode led.
    for find led defective you can check with a 3.6volt battery, put one alimentation on diode thet thurned on weak( anode or chatode) AND try to put other alimentation on diode connected in series, if you find one diode thet turns on your led on with alimentation on anode and chatode ,you find faulty led
  17. The Following 19 Users Say Thank You to fra69 For This Useful Post:
    Air (26th September, 2021), autodigitec (25th January, 2022), BusCan (22nd April, 2024), D0k1 (11th April, 2024), dashradio (8th February, 2021), duzaven (15th January, 2021), eric paris (15th January, 2021), GameTheoryOptimal (25th July, 2022), jlperf (23rd January, 2024), jomberykaso (20th February, 2020), junmab (26th January, 2022), line44 (14th November, 2020), marcolr (11th February, 2020), Meat-Head (7th February, 2020), obd.tech (20th February, 2020), sancaman (30th January, 2022), tomvleeuwen (7th August, 2020)
  18. #28
    May 2009
    Quote Originally Posted by fra69 View Post
    Thanks fra69 .... Did I understand this correctly? You think the dimly lit LEDs are passing a low current circuit 'leak' back through?
    So test with 3.6v battery that they should only illuminate/turn on/conduct in 1 circuit direction only!?
    (Sorry I don't understand the part " AND try to put other alimentation on diode connected in series " .... Is there another diode in series??)
    Please if anyone could clarify my confusion!!
    Where is it possible to purchase replacement LEDs for this & other clusters?
  19. #29
    italy
    Quote Originally Posted by obd.tech View Post
    you can use led from some used cluster. i've many flautly cluster in my warehouse and i use it.
    for explain the problem it's easier show you then explain thet.
    i've repaired many cluster with this problem.
    also golf 6, panda 169, g.punto and other cluster have this problem, but ducato it's most common.
  20. The Following 4 Users Say Thank You to fra69 For This Useful Post:
    BusCan (22nd April, 2024), dashradio (8th February, 2021), junmab (26th April, 2024), obd.tech (21st February, 2020)
  21. #30
    Sep 2010
    Thanks for the info. I tried to test the led as you stated but when using a 3.6v battery the led blew up. This was on a Fiat 500 speedo which suffers the same problem. Do you know the led ratings for replacement? I know they're 3528 PLCC-2, 20mA. Just unsure of foward voltages and mcd
