Results 1 to 9 of 9
    Sep 2019
    Ipswich, Suffolk
    Default KTAG & KESS Drivers and KSuite 2.23 Software
    I've changed my laptop from an old Toughbook to a new Dell and would like to reinstall Suite 2.23 for my KTag and Kess units but I no longer have the driver and software CD's plus the laptop doesn't have a CD drive
    Where can I get KSuite 2.23 for my KTAG and KESS? I have downloaded a few and the software boots but it gives me different errors which I think is because I do not have the correct drivers.
    My KTAG is V7.020 and KESS is V5.017.
    Thanks!
    Sep 2019
    Ipswich, Suffolk
    Also, will the above be ok on Windows 10 or do I need to install XP or 7?
    Member AKH84's Avatar
    Mar 2018
    France
    Drivers are inside the ksuite instal folder, like: c: program, ksuite2.23, driver
    Sep 2019
    Ipswich, Suffolk
    Do you know if they function on Windows 10?
    Quote Originally Posted by AKH84 View Post
    Mar 2018
    France
    yes install drivers in administrator mode, plug your kess or ktag in usb and open ksuite
    Jan 2019
    Best Country of the world, GR
    Once the ksuite software is installed, the drivers are installed (automatically)...
    connect usb and open ksuite. if the protocols are gray, it is problem in micro sd card...
    For better stability recommended use win7.
    Sep 2019
    Ipswich, Suffolk
    It is coming up with a warning then the software freezes. The KTAG and KESS both work fine on my Toughbook running XP though?
    Quote Originally Posted by gas43 View Post
    Jan 2019
    Quote Originally Posted by henson12345 View Post
    Yes...
    Try and win7...
    Jul 2019
    Everywhere
    In windows 8 64bit work good too
  10. The Following User Says Thank You to Johnwick88 For This Useful Post:
    henson12345 (17th October, 2019)
