note: some people report that some interfaces do not connect because of firewall, so disable it when using diagnostics software. it is also recommended to disable internet connection and antivirus. in windows vista is also necessary to have administrator rights and to disable uac.
AS I DONT WANT TO TAKE THE RISK OF LEGAL ACTIONS, ONLY FREE OR NON-MODIFIED SOFTWARE AND PREVIOUSLY EXISTING LINKS IN THIS FORUM OR FOUND IN INTERNET BY GOOGLING, WILL BE RELEASED HERE
ASK OTHER MEMBERS OF FORUM FOR THE SOFTWARE YOU NEED OR GOOGLE IT OR TRY THESE OTHER AUTOMOTIVE SOFTWARE COLLECTIONS:
Automotive Software Collection (diagnostic, tacho, airbag...) Megaupload Rapidshare Torrent download
Automotive Software Collection - Katz Forums
Automotive Software Collection - Rapid.org
Automotive Software Collection - gigle.ws
http://eng2all.com/vb/t25247.html
http://dkgaragesoftware.blogspot.com
VAG-COM 409.1 KKL INTERFACE ----------------------------------------------------------------------------------------
vag-com 311.2-n with keygen
http://www.digital-kaos.co.uk/forums...16/#post302184
http://www.digital-kaos.co.uk/forums...tml#post284272
DISCONNECT INTERNET BEFORE INSTALLING AND RUNNING SOFTWARE
IN VISTA, DISABLE UAC (GOOGLE IT TO KNOW HOW)
vag-com 409.1-s final, i found it on internet by googling
MEGAUPLOAD - The leading online storage and file delivery service
vcds lite 1.0 (new vag-com 409.1)
http://www.digital-kaos.co.uk/forums...racked-113698/
great free alternatives to vag-com 409.1:
monoscan 2.12 supporting kw1281 and kw2000 protocols
requires free registration (for unregistered control units, the connection duration is limited to 60 seconds)
Home (MonoScan)
wbh-diag 0.89 supporting kw1281 protocol
WBH-Diag 0.88 freeware for KW1281 protocol based Non-CAN VAG cars and 409.1 interface
audi-vwtool 2.0.9 supporting kw1281 protocol
http://shotta.big4.pl/photo/KJS%2020...owe/vds209.exe
unidiag 0.4.0.3 for alfa-fiat-opel packed by manocao with 38 def files and 9 dtc files
with corrected Test_BoschABS57ASRTC.def
Digital Kaos
fiat ecu scan for kkl vag-com 409.1 interface
http://www.digital-kaos.co.uk/forums...stered-110099/
http://www.fiatecuscan.net
scantech OBDII 1.35 (iso9141 and kw2000 protocols, non can-bus) for KKL interfaces (vag-com 409.1 blue cable)
http://www.digital-kaos.co.uk/forums/attachments/f104/9888d1264093897-automotive-software-collection-manocao-fullscantechobdii.zip
OBDTool 1.2.60 (iso9141 protocol, non can-bus) for KKL interfaces (vag-com 409.1 blue cable)
http://www.minskaner.narod.ru/obd1260.zip
Collection of D.I.Y. serial OBD2 ALDL dumb interfaces for VAG-COM 409.1 and KKL soft
TECH-2 MULTIPLEXER INTERFACE (OR VAG-COM 409.1 KKL INTERFACE BUT ONLY ENGINE ECU PIN7) -----------------------
mocpo (opcom demo with all measuring blocks)
Mocpo - Download
index_demo
http://www.vezerdiagnosztika.hu/AB-COM/1.zip
http://www.vezerdiagnosztika.hu/AB-COM/2.zip
http://www.vezerdiagnosztika.hu/AB-COM/3.zip
http://www.vezerdiagnosztika.hu/AB-COM/4.zip
http://www.vezerdiagnosztika.hu/TECH...20for%20KL.rar
http://www.millisi.net/download/VAG/TECH2.rar
OP-COM V2 INTERFACE ------------------------------------------------------------------------------------------------
http://opcomforum.yolasite.com
http://www.digital-kaos.co.uk/forums...tml#post364253
last drivers 2.06.00 http://www.digital-kaos.co.uk/forums...tml#post386958
ALL YOU NEED TO REPAIR OPCOM INTERFACE
OPCOMFUT 2.9
v2.9
- No Aktivation in OP-COM Fut needed anymore!
- Creation O***MRD.DLL in Version 1.1.0.0 or 1.0.2.0
http://www.digital-kaos.co.uk/forums...pcomfut29b.rar
source:
OPCOM again.... what so it mean?
file seems to be corrupted but it is not:
rename file to .rar
unrar
rename extracted file to .zip
then unzip and youll find it
ELM327 INTERFACE ----------------------------------------------------------------------------------------------------
scantool.net 1.13
ScanTool.net: OBD-II Software Front End | Get ScanTool.net: OBD-II Software Front End at SourceForge.net
scanmaster elm 1.9 full for elm327 (bugs free)
search on automotive software collections above on top
vauxcheck 1.21 full for elm327
opel cars supported Gendan VauxCheck :: Coverage
Upgrade your ELM327 v1.2a from 9600bps to 34800bps
http://www.digital-kaos.co.uk/forums/f104/elm-interface-buy-94874/#post462810
FTDI DRIVERS AND UTILITIES ------------------------------------------------------------------------------------------
elm327 v1.2a, tech2 and vag-com 409.1 clones drivers
Windows 2000, XP, Server 2003, Vista, Server 2008, Windows 7 and Server 2008 R2 (x86 and x64)
2.06.00 http://www.ftdichip.com/Drivers/CDM/CDM%202.06.00%20WHQL%20Certified.zip
2.06.02 http://www.ftdichip.com/Drivers/CDM/CDM20602.zip
Windows 98 and Millenium
1.09.06 http://www.ftdichip.com/Drivers/VCP/Win98/R10906.zip
Digital Kaos
ftdi drivers uninstaller ftclean
http://www.ftdichip.com/Resources/Utilities/FTClean.zip
mprog3.5 ftdi eeprom programmer
http://www.ftdichip.com/Resources/Utilities/MProg3.5.zip
ft_prog 1.3.1 ftdi eeprom programmer and VNC1L firmware programmer
http://www.ftdichip.com/Resources/Utilities/FT_PROG%20v1.3.1.zip
requires the Microsoft .NET Framework 2.0 installed on your system to run the application
http://www.microsoft.com/downloads/details.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en
OTHER INTERFACES ---------------------------------------------------------------------------------------------------
Uniscan or Euroscan's VISA 1.83 by manocao for u all
RENAULT XR25PC for old cars (fenix, renix...)
Renault XR25PC : XR25 based interface and software
VISA 1.83 MultiBootCD and MultiBootUSB by manocao
http://www.digital-kaos.co.uk/forums...anocao-165650/
build your own ALDL interface: schematics and software
GM 8192/160 Baud ALDL Interface
Digital Kaos
ALDL OBD1 OBD cable OBDI OBD2 engine codes
10 pin to 16 pin op-com adapter pinout and following posts on same page
http://img251.imageshack.us/img251/1...colspinout.jpg
Digital Kaos
Digital Kaos
Digital Kaos
Digital Kaos
Andrew's GM ALDL Stuff...
http://download.efilive.com/Software...5_305_Eval.exe
EFILive V4 Eval License - Valid Thru Dec 2010 - EFILive Forum
EFILive Collate - EFILive Forum
Index of /downloads/tuning-bins/EFILIVE
www.oldholdens.com - /temp/carstuff/VN-VP-VR/aldl/
www.oldholdens.com - /temp/carstuff/aldl/
http://www.ttspowersystems.com/softw...TEST-Setup.zip
SUPERLINKS -----------------------------------------------------------------------------------------------------------
Elm Electronics Help - OBD Links
Check Engine Light OBD2 OBDII scan tool OBD
https://www.scantool.net/support/index.php?_m=knowledgebase&_a=view
DTCSearch.com - Search Engine for OBD-II Diagnostic Trouble Codes (DTCs)
Index of /Scion_Docs
Index of /images/04_xB_Repair_Manual
Index of /dersler/muh100/2007-2008/Cesitli/Deutz Engine
RENAULT DOCUMENTATION | Renault Moteur / Engine
Measurecalc - Conversi?n de Potencia
http://bevo.mercedes-benz.com/bevolistenmain.php
ren
Index of /carmechanic.co
16 pin J1962 OBD-2 car special connector diagram and applications @ pinouts.ru
BUS INIT: ...ERROR - Powered By Kayako eSupport
Category:Fault Codes - Ross-Tech Wiki
ChipTunaWarehouse
OBD2 Interface for diagnostic over OBD
DTC Table
Elm Electronics Products - OBD ICs
Elm Electronics Products - Data Sheets
Google Traducir
How do I know whether my car is OBD-II compliant? - Powered By Kayako eSupport
How to clear or reset the Check Engine Service or Service Engine Soon Light
GM General Motors OBD Trouble Codes
OBD-II Check Engine Light Trouble Codes
BAT Auto Technical-Professional mechanics giving advice-An Educational Site w/ OBD2 Trouble Codes and Technical info & Tool Store.
SRS Module Repair - SRS Airbag Light Reset - Reset Airbag Computers - Manually Reset Airbag - Air Bag Module Repair Service - Airbag SRS Systems - Remove Auto Crash Data
http://youyoukiller.free.fr/ecu/
http://autoecutools.com/download/
http://www.motordiag.cz/download/
http://www.vchecker.com/down/
http://myrezo.free.fr/
http://download.autosvs.com/software/
index_en
Lexus LS400: How to Turn-Off the Air Bag Light / Clearing Diagnostic Code 41
http://www.millisi.net/software-download.htm
http://shotta.big4.pl/photo/KJS%202006/Programy%20do%20interfejs%f3w/OBD%20car/
OBD2 Standards/Terms - obd2crazy.com Tech Info for OBD2 OBDII
OBD-2 ISO 9141-2 (14230-4, KWP2000) simple RS-232 Connector Pinout - AllPinouts
OBDII Diagnostic ScanTools and code-readers
OBD-II Hardware
OBD-II OBD-1 Infos
OBD Productinfo OpelScanner
OBD-II ScanMaster-ELM
OBD-II Productinfo ELM327
OBD-2 Kompatibilit?t
OBD-II Compatibility
OBD-II Abbreviations
OBD-2 Techn. Infos
OBDPros
PCM Fault Codes
PIC18F2580
http://rapid.org/board/showthread.php?t=198809
Reset Air Bag Light
http://www.minsk555.narod.ru/software.htm
http://www.minsk555.narod.ru/index.htm
http://www.minsk555.narod.ru/suppobd.htm
SK Pang Electronics - RS232 Data
AKM Electronics: Technical Information
AKM Electronics - Diagnostic Scanning Software
Which OBD-II protocol is supported by my vehicle? - Powered By Kayako eSupport
http://www.sinodownloads.com/down/download/ecutool/
http://www.berton.es/recursos/indices/INDICE%20VEHICULOS%20OPEL%20V%206-9%20.pdf
http://www.op-com.hu/Downloads_EN.aspx
http://www.remixbg.com/Documentation/BRC/Other/VARIAT_SCELTA_TA010986_1_ML.PDF
http://www.rapidshare1.com/ddl6/opel%20tis/
Motor CORSA X12XE
http://op-com.wikidot.com/en:start
Yahoo! Groups
The Alfa Romeo 145 & 146 Technical Resource Centre - OBD KWP2000 Diagnostics Information
Volo Performance - Chip Tuning Made Easy
Hoofdpagina EN - op-com
http://www.hex.co.za/vaginfo/index.html
http://www.digital-kaos.co.uk/forums/f104/vag-com-409-software-crack-25528/index9.html#post421058
http://www.er-forum.de/obd-diag-dl/
http://www.obd-shop.com/danila/index.php?cid=26&id=27&lang=de
http://sites.google.com/site/outilsobdfacile/telechargement
http://www.forum-auto.com/pole-technique/section12/sujet118225.htm
Freediag - Vehicle Diagnostic Suite
opendiag: By Thread
UniDiag : UniDiag
http://home.wanadoo.nl/sanderqv/diag/
GNC > GNCUSERS • Ver Topic - Scanner OBD2
http://hem.passagen.se/tomasf/obd2/
Software for the vehicle diagnosis
Philippe Boursin - Pedagogie - Injection
Philippe B. de l'Arc - Automobile
http://opcomforum.yolasite.com/
[MIX] OP-COM [Opel diagnostyka] - TYLKO LINKI - polish:Elite:board
OPCOM upgrade i naprawa - Poradniczek - Vectra Klub Polska - strona 11
INFO ------------------------------------------------------------------------------------------------------------------
info about elm327, tech2, op-com amd vag-com interfaces
diagnostics hardware
installing drivers of an interface
best cheapest ebay searches
item, Libros, Revistas y Comics y Juguetes en eBay.es
(whole world, buy it now, lowest price+posting)
keywords: vag kkl, sb kkl, vag can, k+can, tech2, obd2, op-com, elm327, can obd2, obd2 v1.2a, obd2 v1.3, obd2 v1.5a...
manual multiplexer (also for fiat ecuscan, get a longer switch for more pin connections, more info Fiat ECU Scanner - Fiat/Alfa/Lancia ECU Reader and here working vag-com 409.1)
see my build here working vag-com 409.1 and here working vag-com 409.1 other here Modifications and multiplexers for the vehicle diagnosis
