Results 1 to 15 of 19
    Nov 2011
    Default CHEVROLET TRAX with "---" in dash
    Chevy TRAX from 2014
    dash shows "---" instead of the real mileage.
    seems to be a well know problem...
    anyone knows the solution for repair this ?
    BCM = 24C16 / Dash = 93C86 // km value is only in the BCM, not in dash
    (car is like OPEL MOKKA, but MOKKA has different odometer)
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Try to program bsi mileage again and see what happens
    Like in other Opels corrupted dash dump.
    Recently I did Camaro with the same dashes.
    WBR, Marek
    Please do not spam my PM asking for help.
    Use forum, that is why we are here.
    Nov 2011
    Quote Originally Posted by jomberykaso View Post
    i did, by OBDII , and manually , no succes
    all fuses oke, cut off power for a while, resetting, dtc erase etc... no succes either
    i need good dump 93C86 for a TRAX, or even maybe a Chevrolet SONIC (they have the same issues) !
    Dec 2018
    Hello...I had that same problem...TRAX starts well when run..but...if only check engine lights..cluster problem...need to change...is damaged...
    Sep 2016
    Guys post your e2 from clocks or look for insignia thread with same behavior.
    Dec 2010
    I have this file from 93LC86 of Chevrolet Trax cluster that displays "---" instead of the current odometer value.
    Will someone be kind to repair this file for me ?
    rtbdiagnostic's Avatar
    May 2015
    My Tool Room
    try and report............
    'If I helped, please click Thanks +Reputation.. !'
  9. The Following User Says Thank You to rtbdiagnostic For This Useful Post:
    junmab (20th December, 2021)
  10. #9
    Dec 2010
    Thank you very much rtbdiagnostic.
    I will have the car back by tomorrow, and i will report.
  11. #10
    Dec 2010
    No joy with the repaired file.
    Can someone else try to help please ?
    If i'll replace a used cluster, do i need to program it to adapt to the car ?
    Could it be the problem is in the BCM even though i can read the km by OBD ?
    Does any one understand the principle of this problem like with many other Opel/GM cars ?
  12. #11
    Sep 2013
    Try to use other dash file, put correct vin and 4 digits of pincode from bcm. That's all
  13. The Following User Says Thank You to jomberykaso For This Useful Post:
    junmab (22nd December, 2021)
  14. #12
    bubbles69's Avatar
    Somehwere in the South East
    dash has security flag activated in eeprom just like the insignia that go ------ also i fix with another dump and edit vin and pin and all ok as mileage stored only in BCM
  15. The Following User Says Thank You to bubbles69 For This Useful Post:
  16. #13
    Dec 2010
    That is No.1 problem. I ain't got any good file for this cluster.
    I attached the part number and the failed 93LC86 data that shows 3 dashes ( --- ).
    Please advise, i got to find a solution.
  17. #14
    Dec 2010
    So actually Jomberykaso and bubbles 69 you are saying that it is not possible to simply replace a used cluster in these cars ?
  18. #15
    Sep 2013
    No need to buy other used cluster, only get a few dumps, put your original vin and pincode inside dumps and test in the car.
  19. The Following 2 Users Say Thank You to jomberykaso For This Useful Post:
    Crasftsman (22nd December, 2021), junmab (22nd December, 2021)
