Results 1 to 10 of 10
Thread: Toyota RAV4
    Feb 2013
    Lithuania
    Default Toyota RAV4
    hello, toyota diesel ECU 89661-42J50 and i have problem.
    P062f Internal Control Module EEPROM Error
    any help?
    number7hd's Avatar
    Dec 2013
    Code injectors one more time
    If my solution helped You - do not forget to THANKS !!!
    Feb 2013
    Lithuania
    need programe injectors?
    number7hd's Avatar
    Dec 2013
    Yes. I had the same situation.
    Program Injectors once again. Make a ride min 10 kilometers.
    Then erase DTC
    Feb 2013
    Lithuania
    i do thad, but the same? any idea?
    number7hd's Avatar
    Dec 2013
    This error shows up when DPF is FULL.
    What happend that this error shows up? By normal use or someone messed up in ECU using Techstreem ?
    Feb 2013
    Lithuania
    no i use launch, make regeneration?
    number7hd's Avatar
    Dec 2013
    Yes - You can try
    Feb 2013
    Lithuania
    i send you foto with DPF pressure, i think it`s ok, what you think?
    number7hd's Avatar
    Dec 2013
  11. The Following User Says Thank You to number7hd For This Useful Post:
    Edvardas (4th November, 2019)
