i have problem with immo red blink flashing
renault trafic 2007
ecu 0281012658 how can i fix immo thanks for helping
renault trafic 2007
little bb
Can i make immo off
little bb
All keys lost
little bb
pick decode . cut key and program it in , 10 minute job
He have the key - if havent how can see that immo blink
maybe is possible to repair it - change the key coil
immo off is pain in the ass.
you need emulator and cut the can line. If you need the rpm + temp then you will need to install a switch between the ecu and the dash. Funny job
Meat-Head (29th October, 2019)
It not true (about cut lines) not for all types emulators cut is needed it is depend of software implemented inside emulator.
Production and development professional IMMOBILIZER/TCU/ESL/ELV/SRS emulators for all brand cars
PORSCHE / FERRARI / MASERATI / LAMBORGHINI - immobilizer solutions
Well send a link in your next post
Link for Renault the emulator immo with implemented special software : http://www.ecudiag.es/home/2796-emul...-500-kbps.html
yupp something similar with the italian guys stuff... almost 99%Also is implemented „stealth” software technology - in 99% cases
don't need cut canbus network and do not need to use a relay.i made a few pcs in the last month and 2 of them need to be cutted. maybe it's bad luck or depend on the UCH sw dunno
BTW thx for the useful link
Cut wire need ONLY when CANBUS line beyond out the motor controller , further (deeper) in the electrical system is broken like grounded, damage or up to 12v .
If want real deep investigation give logs from CANBUS I teel You what is problem , because I wrote the software for this emulator...![]()
