Results 1 to 12 of 12
    Black Alien's Avatar
    Apr 2019
    Malawi
    Default Isuzu Dmax 2012 dpf off
    Good People.,
    Help me removing DPF in this Isuzu Dmax 2012. I have failed to do with my software.
    I read ecu data on OBD with Kess
    Best regards
    Oct 2018
    hi ecu type.....???
    Babos's Avatar
    Mar 2012
    Quote Originally Posted by tothzsolt View Post
    hi ecu type.....???
    It is transton ecu
    Apr 2019
    Malawi
    Yes,, Transton ECU it is
    Sep 2013
    used KESS clone?
    Oct 2018
    Black Alien
    transton ecu flash file all 1mb not good flash file
    Sep 2013
    Black Alien
    flash file ok
    WinOLS5, custom files for ECU DCU
    Apr 2019
    Malawi
    yes I used Kess Clonned one.... do we have a problem?
    Dec 2013
    This is easy job.
    DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
    Sep 2019
    Ipswich, Suffolk
    Be interested if you read using a Kess v2 clone as I have a 2014 Isuzu Dmax 2.5 to remap for a friend. Was there an issue with writing on these by OBD?
    Jun 2017
    I flashed an Isuzu Dmax with Transtron ECU with kess eu clone. File read was bad, flashing was also bad, maybe had checksum correction error because car started but after one minute engine shut down. Flashed back factory read file, engine was shut off again.
    Thankfully I had a genuine kess with factory file read as backup, that flashed correctly
    Στάλθηκε από το SM-G960F μου χρησιμοποιώντας Tapatalk
    Oct 2019
    Default isuzu-Dmax dpf+dtc off ok
    pass-pm
  13. The Following 2 Users Say Thank You to ko nyein For This Useful Post:
    bangah (26th November, 2020), nabilahmed (22nd October, 2021)
