Results 1 to 9 of 9
    Jan 2017
    Default Dacia Duster 2018 change km ABS
    Hello!
    Dacia Duster, year 2018
    I need change km in ABS.
    Original km 48988km
    New km 17500km
    Eeprom 95128
    ABS nr 0265956628.
    hivrich's Avatar
    Sep 2012
    Ukraine
    Try and report
  3. The Following 3 Users Say Thank You to hivrich For This Useful Post:
    jomberykaso (30th October, 2019), pablos1234 (31st October, 2019), supana (1st October, 2020)
    Jan 2017
    The tester shows 0 km.
    I will do a road test and report.
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    I think hivrich's file is good, what about dash edition?
    Jan 2017
    Dash made UHDS by SMOK
    156alfa's Avatar
    Feb 2012
    greetings from italy
    hello friend
    when a person wants to be helped
    must try to collaborate on these cars
    to see where the anomaly takes place is opportune
    also have the dash file, so post the dash file and you will definitely see the problem
    Greetings from Italy
  8. The Following 3 Users Say Thank You to 156alfa For This Useful Post:
    jomberykaso (30th October, 2019), junmab (31st October, 2019), zckariya70 (2nd November, 2019)
  9. #7
    Jan 2017
    After driving a few km, the mileage rewritten from the meter. You only need to do a TPMS reset a few times because it remembers the mileage when a tire is punctured.
    File colleague hivrich is good.
    Thank you for your help
  10. The Following User Says Thank You to pablos1234 For This Useful Post:
    drpeter (31st October, 2019)
  11. #8
    Nov 2019
    Hello, to modify the km, you have to modify the file in ABS and the dashboard?
  12. #9
    Sep 2013
    Quote Originally Posted by maxiv98 View Post
    Only if it has abs but generally dash + abs
