Results 1 to 15 of 28
    Northern europe
    Default Mercedes W204 2008 - Dash swap - Help Pls !
    I have a W204 2008 where the dash will turn off after it gets hot.
    Instead of trying to repair want to just change cluster with another used one.
    If I buy used cluster there will be warranty on it and can't open.
    Can I read 24C128 eeprom on the table trough the cluster connector or not possible ?
    Clsuter part number : A2045404548
    I have Carprog , FVDI , DP3.
    Thanks in advance.
    P.S. Alternatively , if this is a common problem for this clusters, is there any repair guide ? Some capacitor broken or transistor maybe ?
    Cllau's Avatar
    Mar 2017
    where friends need me
    Mate, to read that Eeprom you need to open the dash....
  3. The Following User Says Thank You to Cllau For This Useful Post:
    jaxone (2nd November, 2019)
    Oct 2017
    Yes, you can connect the cluster on bench and read the eeprom by diagnostics. Then just write the eeprom dump in your donor cluster and all should be fine.
    pepi's Avatar
    You cant just write eeprom data to other dashboard . All you need is to write SSID of original dashboard to the spare dash and of course km stand.
    Upload two dumps and we can prepare your new dump.
  6. The Following User Says Thank You to pepi For This Useful Post:
    Northern europe
    Thanks.
    As far as I understand I can not power up / read dash on bench without a can emulator ?
    Pepi: If not possible to read eeproms by obd or bench , then I will have to open up dash. So why not just swap over the 24C128 ?
  8. #6
    Northern europe
    Quote Originally Posted by Cllau View Post
    I can see FVDI has option to read dash eeprom by obd. Safe ?
  9. #7
    May 2014
    Hi.
    FVDI read eeprom but not all, can not read first 7line.
    There is mileage and SSID.
    SSID is in fifth line...
    Open dash, read 24LC128 eeprom, edit SSID (fifth line) and if new dash has bigger mileage correct it. If lower than EZS don't need correct mileage.
  10. The Following 4 Users Say Thank You to rafalgt For This Useful Post:
    jaxone (2nd November, 2019), Retter (21st October, 2022), Steve182 (14th February, 2025), yomyxmo (8th June, 2020)
  11. #8
    pepi's Avatar
    Quote Originally Posted by jaxone View Post
    Thanks.
    You can write ONLY if your label is 100% same with spare dash. Even then you dont know if was updated dash or no , so better dont do it.
  12. The Following User Says Thank You to pepi For This Useful Post:
  13. #9
    Northern europe
    Quote Originally Posted by pepi View Post
    OK, understand.
    I will just open up and read eeproms from both. Will post dumps as soon as I get donor dash home. Thanks for headsup !
  14. #10
    Northern europe
    Attached Redout from ORI Cluster.
  15. #11
    Northern europe
    Finally "NEW" Cluster arrived.
    It has same part number but I have not connected it to the car to read ID and info.
    Attached Defective Cluster 24C128 ORI and New Cluster 24C128 ORI.
    Can someone please move KM and SSID from "DEFECTIVE" to "NEW" ?
    Thanks in advance.
  16. #12
    Northern europe
    I tried to transfer SSID and KM , can someone please check if correct ?
    Thanks.
  17. #13
    Northern europe
    Well, I wrote my edit on the new cluster eeprom and installed in the car.
    After 2 seconds 999.999km appeared
    I could start the car.
    Then I corrected the mileage in EZS and Dash DP3 and everything seems ok.
    Looking at service assist data on the OLD eeprom, this car has actually drove 477.xxx km .... but hey , he did not come to me to adjust mileage just swap the dash.
    Thanks everyone for the input, I have learned something new today.
  18. #14
    Northern europe
    Quote Originally Posted by rafalgt View Post
    Hi.
    Thanks for the picture, saved me some time.
  19. #15
    omglol's Avatar
    Jan 2009
    Europe
    Reviving old thread ...
    I have the same problem. I need to put used instrument cluster in Mercedes W204 2007. Original one is dead. Unfortunately, I don't have OBD tools for this job. Can I:
    1) read ORIGINAL instrument clusters' EEPROM (24LC128) to extract SSID and mileage
    2A) read USED instrument clusters' EEPROM (24LC128) and put original SSID and original mileage
    2B) read USED instrument clusters' EEPROM (24LC128) and put original SSID and 0 km
    Which procedure is correct, 2A or 2B? How can I avoid mileage getting 999.999km? I don't have tools for EZS. Thanks in advance!
