I just changed my injection pump from my Audi a4 b7 2.5 BDG 2006
I read the ECU EEPROM for login (05758) but when i try to log to engine that code is not accepted, any solution?
I added the same injection pump (reference).
post here what you readed............
need help
now my goal is to buy xp-005
who will help?
hhp (12th November, 2019)
I think you have to read EEPROM from ecu....not Dash
The dump is from VAG DashCAN?
CMD | Alientech K-Tag | Batronix
+++ NO Passwords +++
Just press THX & Rep if i helped you....
Yes, is from dash scan
I think that i need login pin from the donnor car for log in on motor and at adaptation ch50 to add my pin and addapt... but i don't have donnor car pin...
Try make immo off in ECU ....
Recovery Service ,File Service [COLOR=#00ff00][FONT=system]VAG ,PSA,Renault ,FIat IMMO solutions!!BMW solutions!! Volvo solutions!! Audi BCM2 repair ,key programing .module matching !!MB solutions !!! CAS / FEM / BDC Recovery !! Poldiag Keymaster seller
immo off must be done in flash and eeprom
rafal (13th November, 2019)
did you try this procedure details
http://wiki.ross-tech.com/wiki/index..._Pump_Swapping
Procedure is ok but we do not know about pin...is it correct or not. User need read ecu and post here dump.
need help
who will help?
Volker (14th November, 2019)
Yes, i used that procedure, to do that you need donnor car pin and my car pin.
Problem is that for login in Motor i need donnor car pin (i don't have it) and my pin to addapt in channel 50. It is any possibility to find donnor car pin without old car? Directly from injection pump? I don't want to do immo of....
No. You need only pin from your car
need help
who will help?
My pin is not accepted at motor login ....
Or it is a possibility to make a mistake when i try to find the ecu pin, what i should do to find that pin?
