Hello to you all.
20/11/2024 26/02/2025 link updated
64bit drivers for VAS5054 interface.
This is free stuff, so do not complain if is not working with your interface..
You are the only one to blame if something goes wrong, so first make backup of important data,
or test this drivers first inside a Virtual Machine or any testing PC.
Remember, i donīt have responsibility of any kind, any problem you solve it,
i have test it and it works, and it is free for you to test,, only IF YOU WANT.
With this installation my VAS5054 is working under 64bit as a PassThru interface, and iīm able
to run it with Xentry new cars and other softwares that only work under 64bit.
This drivers are not complete tested on other interfaces, so please post your results
to confirm if work or not, and see if it need any changes.
If you have ODIS on same installation you may have problems because the interface
will be used only as PassThru, so you can chose it or use different
windows installations to avoid problems.
Tested on Windows 7,, Win 10 have conflicts.
I have also -Actia-XS-Passthru-64bit-Driver- 1Gen VCI-
working on 64Bit, check my other threads.
Password is already included, just donīt forget to press TANKS and REPUTATION,
it is a way to recognize the work that i have for the drivers you get for FREE.
Roturbo
