Results 1 to 12 of 12
    Aug 2019
    Default prado 2011 eeprom s93a86
    helllo ,
    please i need someones help my eeprom s93a86 is broken and i need the program to insert in a new eeprom
    can that be done??
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Sure, in this link you will find a good file,
    Download file from post #4
    https://www.digital-kaos.co.uk/forum...ght=Prado+2011
    Aug 2019
    hello again,
    thanx for ur help but how can i change my milage to 83 km
    Sep 2013
    car is 2011 and you want to put it 83 kms?......nice joke....
    Sep 2013
    now press the Thanks button located on the bottom left of each post
  6. The Following User Says Thank You to jomberykaso For This Useful Post:
    zouzanda (15th November, 2019)
    Aug 2019
    hello again,
    just one more question should i just flash the code into the eeprom using 16bit ?
    and i tried to use tachosoft to calculate the milage but the numbers dont match is there any alternative?
    thanks in advance
    Sep 2013
    You only have to put one of my files in your eeprom.
    Is this your first job?
    Aug 2019
    yes it is my first i am trying to learn but until now it is a disaster
    thanx for the help
  10. #9
    Sep 2013
    It's ok. You have to re-write file i posted with mileage you wanted, write that file always in 16 bits, tell me what programmer do you have to do this job?
  11. #10
    Aug 2019
    i am using tl866 II puls
  12. #11
    Sep 2013
    Check your inbox notification
  13. #12
    Aug 2019
    solved by the one and only jomberykaso
  14. The Following User Says Thank You to zouzanda For This Useful Post:
    jomberykaso (15th November, 2019)
