Results 1 to 15 of 23
    Dec 2018
    Default Code from Dump Blaupunkt Woodstock SQR88 (BP8890)
    can you tell me what's the Code is?
    BP8890 with MC68HC11A8.
    Code must start with 1 or nothing.
    Thanks.
    Dec 2012
    Try 1594........
    Dec 2018
    nope.
    Dec 2018
    Any other suggestions?
    Dec 2012
    Try this dump, code is 1234
  6. The Following User Says Thank You to andm266 For This Useful Post:
    chimpyshorts (27th October, 2022)
    Dec 2018
    Ok, it would be great if someone could do it with my dump, because I already soldered it in again... 🙄
    Belarus
    BLAUPUNKT WOODSTOCK SQR88 BP8890 CODE 0000-9999 7 648 890 410 BLAUPUNKT MC68HC11A8 (8925900052 ZC98378CFN BP5WD17) MCU TDA7241 x 4 woodstock_sqr88.jpg
    try 0369
    Dec 2018
    Thanks! But don't work either... 🤔
  10. #9
    Dec 2012
    The code is in cells 18A, 18B and repeated in cells 1C5, 1C6.
    Your dump SQR88 looks bad.
  11. The Following 2 Users Say Thank You to andm266 For This Useful Post:
    chimpyshorts (27th October, 2022), ikaruga (18th November, 2019)
  12. #10
    Dec 2018
    Thanks! That's not so good. Ok, i'll solder it out again.
  13. #11
    Some lateral thinking,
    find another dump that has requested a decode and clone?
  14. #12
    Dec 2012
    Quote Originally Posted by ikaruga View Post
    When you desolder it, can you read the ROM?
  15. #13
    Dec 2018
    Quote Originally Posted by albertros View Post
    A dump with known Code like 1234 is perfect too.
    Quote Originally Posted by andm266 View Post
    I have a XProg-M 5.5.5 here. But it makes some "device is silent" errors with the HC11A8...?!
    So I sended it to a friend who was able to read the EEPROM (obviously it was damaged)
    Now I will write your dump.
  16. #14
    Dec 2018
    Just another question. Is it possible to read the EEPROM without desolder the MCU? (I don't have much experience)
  17. #15
    Dec 2012
    Yes.It is possible, but all connections to pins should be cut: 20,21,17,2 on both sides of the circuit board.
    And use the simple interface on MAX232 and the program for example Motorola Cracker.
  18. The Following User Says Thank You to andm266 For This Useful Post:
