Results 1 to 5 of 5
    Feb 2019
    Default EGR DELETE MJD6F3HW04P 51843354 3641PK90 FIAT GRANDE PUNTO 1,3MJT
    Hello
    I need EGR delete from fiat grande punto 1,3 MJT
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by patryk3112 View Post
    Hello
    here EGR off no chs...
    pass pm
    mjt6f3_EGR_OFF.bin.rar
  3. The Following User Says Thank You to Panathaole For This Useful Post:
    patryk3112 (18th November, 2019)
    Oct 2018
    patryk3112
    hi 100% egr off and chk ok
    test and report
    thnx..........pass pm
  5. The Following User Says Thank You to tothzsolt For This Useful Post:
  6. #4
    Feb 2019
    egr dtc gone but now I have 3 errors:
    P2081 temperature sensor DPF
    P2452 pressure sensor DPF
    P0045 turbo actuator command
    before was only one about EGR
    Oct 2018
    patryk3112
    with this type of car when the egr goes off and the dpf goes off, but the particular operation must be done
    INSTRUCTION
    1.Reset particular filter soot counter
    2.Delete all errors from the control unit
    3.Make sure that all the DPF related sensor are connected
    4.write the file to the control unit
    5.Empty the DPF
    rar pass the same I sent you
