    Jul 2019
    Lebanon
    Default FVDI 2014 Installation Problem
    Hi, I tried to install FVDI 2014 ID: F01954, after installing I tried to lunche the application , first windows an error : " mfc110.dll is not found", tried to reinstall the FVDI application gave the same error, also tried to reinstall all versions of VISUAL STUDIO C++ and the same error, so I tried to install manually "mfc110.dll" obtained from https://www.dllme.com, the error became "The application was unable to start correctly (0xc000007b), Click Ok to close the application", I have this installation on my four laptops with different WINDOWS versions: XP, Win 7 Ultimate, Win 10 all 64 bits,all gave the same error.
    Please any one could help in order to solve this problem and get successfully working FVDI .
    Thanks...
    Dec 2014
    Lithuania
    at 64 bit did not start. 32bit All ok
  3. The Following User Says Thank You to duzi For This Useful Post:
    hussamultratec (19th November, 2019)
    Oct 2018
    I run 64bit I got it installed on windows 10, just download it directly from flyobd.
  5. The Following User Says Thank You to bioggy For This Useful Post:
  6. #4
    Jul 2019
    Lebanon
    Hi, I did, got the same issue
    EU
    in instalation folder of fvdi C:\Program Files (x86)\Abrites Commander Software List you will find folder pach , install all files and will be fine
    Quote Originally Posted by hussamultratec View Post
  8. The Following 2 Users Say Thank You to iozo For This Useful Post:
    castin (24th November, 2021), szuwarik (1st October, 2022)
  9. #6
    Aug 2016
    Solution for Windows 7 or W10 with 64 bit:
    in the program folder to replace file 2 dll files on the 32-bit variant
    1). MSVCR110.DLL
    2). MFC110U.DLL
    After that the program will start and error message 0xc000007b is fixed!
  10. The Following User Says Thank You to jo62mj For This Useful Post:
    dusichek2012 (24th March, 2023)
