Originally Posted by
garryo
Hi, can any body help, I have a 107 with semi auto box, it has a immobiliser problem, car fires then dies, it has a semi auto box and i am struggling to find wiring diagram for immob box. taken to of dash off found green wire wich was dead when unplugged, autdoata only list one pin for this model and that is pin 51 which was a black wire, that was dead also when unplugged but went to earth when plugged into engine ecu, cut the wire and joined with green wire, car started and run. took battery off to tidy wiring up and refitted battery, now will only fire again, no faults in immobiliser unit, see the key in live data and says its correct and all seems fine, but in engine ecu has a communication fault with immobiliser B2799. so I need to check whether I am missing something else like another wire to ecu not shown on the autodata
