Car is 2004 and sometimes has problem reading key (fast blinking led). I read eeprom make pcf7936 with tango as I always do but then car not start and led every time ignition ON blinking fast. Remote works ok.
DTC: DF067 Ring key identification -> Decoder connection Open circuit or short circuit to +12v
Replaced ignition coil,same problem, put other UCH-N2 (with wrong transponder) shows same error DF067 Ring key identification -> Decoder connection Open circuit or short circuit to +12v.
I added key 3 and 4, when read actual data shows that key is 3 or 4, so how can show error coil id see key number
Any tips
