Results 1 to 9 of 9
    Apr 2019
    Default Corsa D BCM reset
    If this is on the wrong forum im sorry and please direct me in the right way. On that note does anyone know the procedure to reset a BCM on a Vauxhall Corsa D 2008? I can't remember the engine code from the top of my head. I have vaux-com and have been told this can do it but dont know the procedure. i know the vehicle needs a BCM reset as the battery has gone flat.
    any help would be much appriciated.
    Thank You
    Aug 2018
    East Pole
    Hello, this is a common problem on Corsa D. If you have the Car pass, you can do it. Also, might be not just a reset procedure needed, but a corrupted memory. If you dont know what does this issue querries, it will be a little bit hard for you to mak the car work again.
    Bllinda's Avatar
    Baltic
    https://www.digital-kaos.co.uk/forum...oduce-Yourself
    Quote Originally Posted by bbooth1991 View Post
    Thank You
    today
    A topic that interests me
    Feb 2013
    UK Bristol
    Hi there. I writed few times wrong pincode to bcm, now refused me with error like in photo.
    Did you know how reset this, switch ignition on and wait how long? I wait 1h:10 still.dont acceprt.
    Any idea?
    My post helps you? Please Hit Buttons
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Thank You
    If you want to make any programming it to the car you must have the cars correct security code PIN.....
    Otherwise you are not be able to do anything....
    Feb 2013
    UK Bristol
    Yes i got correct pin code.. we tried adapt another ecu, we have pin code to another ecu and code to currently ecu..bcm, info.display i and works.. but we do something wrong on adaptation process and now Bcm refusing pin code, so presume must wait for some time to unlock counter, but dont know long and how exacly do this.
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    my answer has for bbooth1991 anyway......
    try to disconnect the battery for a few minutes, google your question, you should find the answer.....you had try to leave the ignition on with op com connected?
    Bllinda's Avatar
    Baltic
    Read mw and.nec,mcu
    Quote Originally Posted by pocinas View Post
    today
    t77's Avatar
    Poland Lodz
    Hello Pocinas I was this same trouble like you .......wait for lock time off and enter PIN in revers mode for ex PIN is 1234 enter 4321 and thats all for me was works.I used OPCOM
