Results 1 to 11 of 11
    Sep 2015
    Default Peugeot 508 RXH Hybrid4 P1AC4
    Hello.
    I have a 2013 Peugeot 508 RXH with Hybrid4 system.
    About a month ago car has started to make a bad sounds and after 150 km noises become much louder. Tow to home and start checking - reversible alternator bearing fell apart. I'm removed it (i'm working in car garage) and replaced a bearing. Everything seems ok, but after replace there was a few errors in HCU1: P16B5, P1AC4, U12C6 (4 times), U0167 and one in HCU2: P1B1B. None of them are able to clear, not even for a moment.
    Since I have a possibility to use a Peugeot diagnostic software (Pass-Thru) connected and make a belt replace procedure. Then every error vanished. And hybrid working, I'm been able to drive it, but when I speed up and then start braking on dash there is "Engine fault". In engine ECU - no errors, in ABS/ESP - no errors (replaced electric vacuum pump cause in fell apart inside, after that replace a fuse and make a reinitialisation procedure in ABS ecu). In HCU1 - P1AC4 and U12C6 (again 4 times). Im been able to clear them, but they still coming back (no pattern here - sometimes its 20km, sometimes 1,5 km.)
    Any ideas? What to check?
    Thanks in advance, Dave
    Sep 2015
    I managed to solve this problem by myself. If anyone have this in future - try to connect additional ground cable to rear traction engine (electric one) and run Adapt procedure of reversible alternator and traction engine again. In my case It work like a miracle. No more errors till now
  3. The Following 3 Users Say Thank You to Dawiww For This Useful Post:
    Louislesinge (31st March, 2020), Meat-Head (14th December, 2019), mexanico1971 (6th April, 2020)
    Meat-Head's Avatar
    Great to hear unfixable french stuff fixed.
    do you HAVE to yo on line to program belt?
    sounds like steel block and aluminium corroded
    Sep 2015
    Yes, online programming was needed. One token valid for one week.
  6. The Following User Says Thank You to Dawiww For This Useful Post:
    Meat-Head (22nd December, 2019)
    Nov 2016
    Default Hybrid4
    Quote Originally Posted by Dawiww View Post
    Hi, can I ask what interweave did you use for passthru please? As I’m using kts570 and I have no access to the hybrid module at all through for some reason says “no colculator” only I think 3 modules are available
  8. #6
    Sep 2015
    Hello. I'm using kta560. Are you from Poland? Your nick is suggesting this. If yes - so am I. Maybe this will be easier to communicate
  9. #7
    Nov 2016
    Default Hybrid4
    Witam, Tak z polski ale nie wiem czy można tak wiec 570 powinna jeszcze lepiej działać ale myśle ze to może być spowodowane tym ze mam Windows 10 64bit i dlatego mam brak kalkulatora wszędzie. Tak poza tym to auto pochodzi z aukcji i było wszytko ok powiedzmy oprócz hybrydy i airbag ale wszytko inne działało
    hybrada miała tylko jeden błąd Nie pamiętam ale coś związane z reduktorem sprzęgła i nie załączal jej tylko na początku była dostępna a po wrzuceniu biegu już nie. Wiec wyjąłem sensor położenia i prędkości było pełno na nich dosyć dużych opiłków i mało oleju. Po czyszczeniu i zalaniu nowego oleju poskładane wszytko i jest masakra auto nie odpala i błędów przybyło
    p1b66- Electric Drove motor magnet. Flux calibration implausible
    p0c17- rotor position sensor position not lerned
    woec oczywiście jest potrzebna adaptacja z czego kts niby jest opcja i przechodzi ale nic to nie zmienia i pytanie jest czy reduktor to śmieć już i dlatego elektryka pokazuje ze ok a ja mechanika rozsypana czy potrzebny jest Diagbox żeby to zrobić
    z tym autem to w ogóle masakra bo nawet do bsi nie mogę wejść kts-em chyba ze mi kabel siada bo już w jednym Volvo miałem problem żeby wejść do ecu ale to by było trochę dziwne ze nie mam połączenia tylko z niektórymi modułami. Już mi głowa chyba wyparowała może jakiś numer telefonu poproszę ro zadzwonię jak będę coś działał. Jutro zamierzam podłożyć kompa z innym systemem ale chyba teraz znów będę musiał wykupić token bo jest przypisany do komputera dzięki za odpowiedz
  10. #8
    Meat-Head's Avatar
    ENGLISH ONLY WILL YOU. HOW DOES ANYBODY KNOW YOUR NOT DISCUSSING
    THE HOT BYRD FROM THE PARTS DEPARTMENT
  11. #9
    Nov 2016
    Hi, i cant send you private Messages as its says that you have full inbox
  12. #10
    Sep 2015
    Ok, cleared my inbox, fell free to send PW
  13. The Following User Says Thank You to Dawiww For This Useful Post:
    agencik (2nd April, 2020)
  14. #11
    Nov 2016
    Did you gry the Message?
