Results 1 to 10 of 10
    Dec 2019
    Default bmw e46 vin change
    hello guys , im in the middle of my e46 manual swap and found that my cluster has been changed by previous owner. yep the vin is incorrect this wont let me code some things in car so i came here looking for a solution.
    read on some other forums tha i need to replace the cluster eeprom chip and reprogam it. i used pasoft to get the bin file from the cluster and modify it to have the vin back to 0 but dont know if thats the way to go also and most importantly is that i need to know wich chip to buy, the one in my cluster says b96ag b58 608 and the algorithm on pasoft says 93s66-e46, the cluster fgstnr says eh75365 and my cars vin is cb24731
    please let me know if im missing something cause this is my first time diy programing :P
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    B58608 = 93c66
    That is the eeprom
    Jun 2018
    CD43
    Quote Originally Posted by bimmerzoku View Post
    Yes you are missing a bit, read the eeprom and post dump. Or use NCSexpert to flash your LCM VO to your Kombi.
    Dec 2019
    delete this please
    Dec 2019
    delete this one to
    Dec 2019
    Quote Originally Posted by rocktumbl3r View Post
    Im lost at (dump) whats that? Lol
    Dec 2019
    Quote Originally Posted by jomberykaso View Post
    B58608 = 93c66
    That is the eeprom
    In the pasoft it says its 93s66 im so confused right now
    maybe this file?
    Dec 2019
    ???????????? Please help ��
    Dec 2019
    help please
    Jun 2011
    Northamptonshire, UK
    You ideally could do with reading the eeprom with a programmer like xprog or upa.. then if you upload it here someone shall change the chassis number to the correct one and also the mileage..
    you do not need to replace the eeprom on this type of cluster..
    Sent from my iPhone using Tapatalk Pro
