Results 1 to 13 of 13
    ysftzcn's Avatar
    Nov 2008
    Default Astra H 1.3 CDTI EGR Off
    Hi DK, I need EGR Off solution for my car. Can anyone help me ?
    HW: MAREL0100
    SW: 3308AB71
    VIN nr.:
    SW ver.: 0003
    Spare:
    Engine: Z13DTH
    HW Ver.:
    SW upg.:
    Installation:
    Feb 2019
    Default ASTRA H EGR OFF
    Hi.Try this inform to PM.
    Astra EGR OFF
    Pass=Thanks+rep.
  3. The Following 3 Users Say Thank You to lion1972 For This Useful Post:
    0nur (1st February, 2020), gokhanustdag (17th April, 2022), ysftzcn (8th December, 2019)
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by ysftzcn View Post
    HW: MAREL0100
    SW: 3308AB71
    VIN nr.:
    SW ver.: 0003
    Spare:
    Engine: Z13DTH
    HW Ver.:
    SW upg.:
    Installation:
    I think if you make egr off without dpf off, you should have error........
  5. The Following User Says Thank You to Panathaole For This Useful Post:
  6. #4
    ysftzcn's Avatar
    Nov 2008
    Quote Originally Posted by Panathaole View Post
    Why my friend ?
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    unfortunately i can't find were i read it here ...
    i hope i'm wrong ...
    try these here ...
    egr off
    dpf & egr off (in a case......)
    good luck...
  8. The Following 2 Users Say Thank You to Panathaole For This Useful Post:
  9. #6
    ysftzcn's Avatar
    Nov 2008
    Ok, I will try it and report
    Thank you my friend
  10. #7
    Mar 2018
    hello
    can someone make egr off for me
    W: MAREL0100
    SW: 3308AB71
    VIN nr.: W0L0AHL4882104859
    SW ver.: 0003
    Spare:
    Engine: Z13DTH
    HW Ver.:
    SW upg.:
    Installation:
  11. #8
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by 0nur View Post
    hello
    W: MAREL0100
    SW: 3308AB71
    SW ver.: 0003
    Spare:
    Engine: Z13DTH
    HW Ver.:
    SW upg.:
    Installation:
    here
    EGR off correct cks on writing pass via pm....
    astra1,3_egr_off_no_cks.rar
  12. The Following 2 Users Say Thank You to Panathaole For This Useful Post:
  13. #9
    Mar 2018
    this solution egr remover
    I'm looking for a manual solution
    thank you
  14. #10
    Babos's Avatar
    Mar 2012
    thank you
    I can to do for you manual solution, if you want write me.
  15. #11
    Mar 2018
    Quote Originally Posted by Babos View Post
    free solution ?
  16. #12
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    thank you
    What do you mean egr remover solution? That is the EGR off in this ecu, With this edit always stay close.... you have errors?
  17. #13
    jurebv's Avatar
    Dec 2017
    Croatia
    here you can try
    manual off
    3 values changed
    84670 - EGR gov. - Battery voltage threshold for shut-off enabling
    84674 - EGR gov. - Time after which EGR is shut of at low-idle
    8468C - EGR gov. - Threshold on rpm for EGR shut-off
    BR
    2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
    FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
    Official Magicmotorsport Distributor
    Official Autotuner Distributor
    Official Alientech Distributor
  18. The Following 3 Users Say Thank You to jurebv For This Useful Post:
    0nur (1st February, 2020), GaizkaV8 (15th September, 2023), gokhanustdag (17th April, 2022)
