Results 1 to 11 of 11
    Dec 2019
    Default Digiprog 3 - mondeo MK3 2005 - cluster pinout
    Hello.
    I would like to correct mileage on my Mondeo MK3 2005 (lift) cluster. I have Digiprog 3 and as i noticed the chip inside cluster is HC12 so I need the ST 51/2 adapter. Where should i connect it?
    My adapter has black, red, orange and brown cable.
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    What about Digiprog pdf manuals when you bought that tool?
    Dec 2019
    i dont have it
    Oct 2018
    Not sure.. Earth maybe?
    Here's your pinout. You don't need +12v for reading-writing eeprom. MCU is unprotected.
    All characters, objects and events described in this message are entirely fictional. Any resemblance to actual events, objects or persons either living or dead is purely coincidental.
  5. The Following User Says Thank You to xufo For This Useful Post:
    haxigi (9th December, 2019)
    Dec 2019
    Quote Originally Posted by xufo View Post
    ok great so now adapter has 4 cables and here i can see are 5 pinouts. +12V is no needed. Which colour should be where plugged?
    ST51 adapter found on the Internet has 4 cables too but in different colours: green, yellow, brown, beige
    Mine ST51 adapter has: black, red, brown and orange.
    oh i found this:
    13-棕(brown) 13-黑(black)
    18-黄(yellow) 18-棕(brown)
    25-白(white) 25-橙(orange)
    17-绿(green) 17-红(red)
    so black and red i know where to connect.
    What colour is RESET?
    Dec 2019
    My ST51 pins - which one is RESET and BKGD?
    clusters's Avatar
    Mar 2015
    Canada
    here, credit to HCIP for this
  9. The Following User Says Thank You to clusters For This Useful Post:
  10. #8
    Dec 2019
    Quote Originally Posted by clusters View Post
    According to this schema - WHITE +12 V - ORANGE - connect with +12V or +5V on xufos diagram?
  11. #9
    Sep 2013
    Wire colors are not important. Use a multimeter to know which one is bkgd, reset, vcc and ground. Now it is easier than before because Clusters posted info you needed
  12. The Following User Says Thank You to jomberykaso For This Useful Post:
  13. #10
    Dec 2019
    Quote Originally Posted by jomberykaso View Post
    but xufo posted:
    "Here's your pinout. You don't need +12v for reading-writing eeprom. MCU is unprotected."
    so i don't need to connect white/orange pin to +12V but where then? To +5V?
  14. #11
    Dec 2019
    ok i got it.
    only GND, BKGD and RESET is needed to be connected.
    everything is working fine
    thanks!
