Hi guys please my cas 3 is dead after fail programming
MINI R56
CAS3 61.34-9147184-01
CPU 0L15Y
I have no ignition lights,,says faulty cas on dtc
Many thanks in advance
MINI R56
CPU 0L15Y
and where is data? or did you want files to write and sync... later?
Yes,,correct
I have no ignition power on CAS,,,Seams flash is been deleted..
My problem is terminal 15,,,when I insert the key as no power on CAS...
ECU Mini Cooper D R56 1.6 80kW 9HZ 2007 0281014295 7808778
CAS61.35-9147184-01
...........tr this
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
PSAXSEVOLUTION (14th December, 2019)
this is not ok....too small
and what size you need
eeprom.bin 4kb
flash.bin 2048kb
I have xprog box to write it...
can you help me please with this original flash..
My problem is terminal 15,,,when I insert the key as no power on CAS and ELV...
CAS61.35-9147184-01
CPU 0L15Y
hi what do for kill cas
readings made today by vvdi prog
Can anyone correct the eprom and flash...
I have no signal when insert key,,Only airbag light cames up,,,the rest nothing
Need big help please
bay tools to write deferent size when you need it,
if i faind xprog format i will give you later![]()
A friend on garage kill it programming with ista-p,,the stupid man programm it without KL15,,,of course at the end does not code it because the kl15 line is not detected...
Mickey mouse garage shop...
No one as flash dump for this cas?
ECU Mini Cooper D R56 year2007 1.6 80kW 9HZ 2007 0281014295 7808778
CPU 0L15Y
tr it not from same cas,
but you dont have nothing to lose
You are the only person willing to help me,with so many Gurus on here no one is helping.
I will try it and let you know the result,,since I have nothing to loose like you said..
I will find solution in the end & I will post the result to you...Nothing is impossible to achive
Br
Psa
in future you can by here llitle more on dk and you will get quick help from many members![]()
PSAXSEVOLUTION (16th December, 2019), Stelaras26 (24th December, 2019)
solved......CGDI solved my problem with kl15,,no power at CAS ...
Car is running now but as a problem with EPS/ELV...
CGDI bmw solved the problem with kl15,,connect the tool and read the keys and made downgrade on soft....this way lets you detect the kl15 line on cas....
As soon it starts to downgrade will make a noise on central electric on the foot right side...Relé will make a click and you ready to go....
I wait about 3 minuts to downgrade the software of cas by OBDII and after that lights on dash came up again...
Just info:::CGDI BMW is very good for keys and cas...top on minis...
Info add on 19-12-2019
I find a way of turning the kl15 ON when all dash have no lights or key is not turning ON 2 POSITION(Ligths on dash)
Normally when you insert the key and you have no ligths on ignition,,,means the car is dead or in boot mode....
If you put a diagnostic tool the result is no communication with DME and other modules like CAS,ELV,JBC,ETC
Try the same way on 4 cars,,BMW f30 ,mini r56,BMW f10, BMW e60....the result is the same,,works 100%...
