Results 1 to 9 of 9
    Aug 2013
    uk
    Default Nissan xtrail 2003 denso 23710-8H800 Virgin Help
    hey guys
    if possible could someone take a look at this. looking for virgin file if possible.
    nissan xtrail
    Denso 23710-8H800
    Eep 93c56
    problem is immo.... immo box has been replaced.
    if i can get virgin or immo off or where to get emulator that will work with type.
    any help will be great
    br
    thayer201
    If i helped.... please dont forget to press the THANKS + REP buttons .
  2. The Following User Says Thank You to thayer201 For This Useful Post:
    7DDR7 (5th September, 2024)
  3. #2
    no need make virign, if you have new immo box use diagnostic tool for match. immo off is possible, if need emulator send PM
  4. The Following User Says Thank You to okura For This Useful Post:
    thayer201 (12th December, 2019)
  5. #3
    Aug 2013
    uk
    No immo box is of secondhand not new can it still be done? i thought not?,
    Pm sent
  6. #4
    Aug 2013
    uk
    Anyone able to virgin this dump?
    no need virign, you can use diagnostic tool for match
  8. The Following User Says Thank You to okura For This Useful Post:
    thayer201 (16th December, 2019)
  9. #6
    Apr 2011
    i have same problem - need immo off
    Nissan Xtrail 2.2 Dci 2005
    ecu Denso
    23710 8H800
    275800 1181
    eeprom 93C56
    NATS pincode is 8934
    Need pinout for connecting emulator
    Thanks in advanced
    Mat
  10. The Following User Says Thank You to mcgywer For This Useful Post:
  11. #7
    avital's Avatar
    In case you do not have a schematic (pinout) for the ECU, the easiest way there is a connection with the emulator to the immobilizer wires or the immobilizer box plug:
    When you can't find the location of the sync bytes in the ECU, there is also a very simple solution :
    connect any diagnostic device tool and perform the function add key, during this procedure, the emulator will be added to your ECU (of course, the pin is delivered and stored inside the emulator - You dont need know PIN from the car ) you only have to use EMULATOR PIN it in the key adding function.
    Production and development professional IMMOBILIZER/TCU/ESL/ELV/SRS emulators for all brand cars
    PORSCHE / FERRARI / MASERATI / LAMBORGHINI - immobilizer solutions
  12. The Following 2 Users Say Thank You to avital For This Useful Post:
    danielif (20th June, 2024), mcgywer (20th November, 2020)
  13. #8
    Dec 2018
    Hi Friends. I have the same ecu. Julie emulator from Carlambo. Does anyone know in which addresses I should enter 93c56 in the memory?
  14. #9
    Sep 2024
    KZ
    Hi, thanks
