hello can you help me to synchronous Ford Focus dash and cluster after batery die no star at all after make resol all pin out from the dash clear the mistake and not star the car after read i get in the ecu this problem immobilizer id does not match i read the ecu bosh-0 281 012 486 5m51012a650-lb 6BUB EEPROM 95160 CAN YOU CHEK IT EVERYTHING IS OKEY AND DASH IS WIT MC9S12H256 1K76X
do i need to read also the box with the fuse insede there is also eeprom 95040?
