Results 1 to 3 of 3
    Jan 2018
    Default Fiat Doblo 1.3 Multijet - bad starts
    Hi, Main problem was that engine didn't start every time.
    It was starter and oxidation on cables. New starter mounted, oxidation removed.
    Now it cranks good, before it was cranking on slow rpm, now rpm of starter are still high, so it's good.
    But after starter there appeared new problem. It starts on good rpm but engine is long cranking and engine will start after 5-9 seconds of cranking. It sounds like fuel pump don't make good pressure and it need some rotations to start.
    Have somebody same problem as me ?
    Thanks for any help.
    Meat-Head's Avatar
    I would check rpm sensor incase its got contaminated with pig uranating or other
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    peetee25 (22nd December, 2019)
    Jan 2018
    Thanks for reply, I'll check.
    Odoslané z VTR-L09 pomocou Tapatalku
