    Top Poster autohaus's Avatar
    Jul 2013
    Default BMW MS45 SERIOUS CHECKSUM ERROR
    Hi guys, can i please get help to correct checksum on flash, no obd communications, so i cant even update software.
    attached are all my ktag reads
    Kind Regards
    A.H
    Oct 2018
    you use ktag original
    Jul 2013
    i have done many other ms45 with my current ktag, with out issues... if i write another flash dump, my ecu responds, but if i write ISN to EWS, i get " irreversible anti tampering" fault
    May 2017
    your flash is corrupted... not chks error.
    Post good flashfile from good backup ... not yours.
    Also post good ews read and I will write ISN inside...
    So you can sync with inpa.
    Jul 2013
    Do you perhaps have a set, DME AND EWS match that i can use? preferably 3.0i
    will pay if its with popcorn limiter at 3.700rpms
    May 2017
    popcorn @3700 ... bullshit. Engine can rev much more mate...
    No havent got pair for all. + you need Z4 3.0i ... 530i... isnt same... different coding... wouldnt work good.
