    Top Poster immyrs200's Avatar
    Manchester
    Default fabia VRS 1.9 TDI edc15p (dtc delete)
    dtc help remove edc15p
    Skoda Fabia VRS 1.9 TDI
    Please can someone help remove dtc (1) - 19557- Motor for intake manifold flap (v157) P3101 open/short to ground
    (2) - 19558- Motor for intake manifold flap (v157) P3102 No Signal
    I will upload the vag com read. Cylinder 1 glowplug has been replaced so that fault code is now fixed.
    it is already a stage 1 map on the car. Faults are present due to egr and intake manifold flap delete.
    Thankyou
    Jun 2018
    Bulgariq
    Quote Originally Posted by immyrs200 View Post
    Thankyou
    Test and Report
    pass-PM
  3. The Following User Says Thank You to naskochipa For This Useful Post:
    immyrs200 (4th January, 2020)
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    here you have pass in PM!
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  5. The Following User Says Thank You to AVDigitale For This Useful Post:
  6. #4
    Manchester
    After looking at both files, i realised that your file was complete dtc erase, i did not use your file but thankyou anyway far taking time out to help me...
    regards
    immy
    Manchester
    Quote Originally Posted by AVDigitale View Post
    aThankyou for helpoing me. Worked a treat ��������������������
  8. #6
    AVDigitale's Avatar
    Apr 2017
    in my file not all dtc off check good and is working solution
    is good to add thnx and reputation if filw works
    File Service
