Results 1 to 15 of 17
    Dec 2015
    Portugal
    Default Nissan Qashqai J10 key programming problem P1610 and P1615 DTC
    I have a problem programming a keyless for a Nissan Qashqai J10. First I try to program with MVP the programming sequence goes OK, but at end, neither customer key neither new key start the car.
    Now I have IM608 also try to program key, but same problem.
    DTC P1610 and P1615.
    The programming sequence goes OK, immo light flashes 5 times, transponder block, but at end key don't start the car.
    Nissan Qashqai J10 VIN SJNFCAJ10U1125013
    Year 2007
    Bcm label 3 C4f1. Part number JD12CED.
    284B2-JD12C.
    Already looked at some posts, but can't see a solution, or the only solution I found is new BCM and ECU from dealer. There is no other option?
    New I-key :
    https://drive.google.com/file/d/1545...w?usp=drivesdk
    https://drive.google.com/file/d/1518...w?usp=drivesdk
    Thanks in advance and happy new year.
    busaman's Avatar
    suffolk uk
    i have one with similar faults p0611 injector coding and p1612 chain of immu i have tried many eep files and a few flash files so far no luck but im not sure maxysys or launch x431 tools i have are good enough for the job even though it goes through the process.
    7.31sec@203.3mph
    rafal's Avatar
    UK - PL
    [P1610]: LOCK MODE (dead lock mode)
    [P1615]: DIFFERENCE OF KEY (BCM has received the ID signal of key and identified it
    as the illegal)
    NATS will enter into dead lock mode if using an unregistered or invalid key to start the
    engine for more than five times, at this time, even though the correct car key also can not
    normally start the engine. To unlock the mode, the system shall be initialized again. If the
    detected DTCs are related to engine system, the related DTCs will also display on ECM.
    Before clearing the DTCs memory on NATS, firstly check the DTCs on engine system
    because while deleting the self-diagnostic codes of NATS, the memory on the "engine"
    self-diagnosis system will also be cleared.
    Perform "C/U INTIALIZATION again
    X-431 or CONSULT-II will do job well
    need help
    now my goal is to buy xp-005
    who will help?
  4. The Following 4 Users Say Thank You to rafal For This Useful Post:
    Faraday (17th September, 2020), lmqcatarino (6th January, 2020), rokibar (12th July, 2021), zzappy (5th March, 2024)
    busaman's Avatar
    suffolk uk
    i have tried the process many times still no luck i have registerd the steering lock also i am thinking one of the 3 switches attached to the ign barrel may not be working correctly as it never completes the process the i-key has been de-registered that does work but will not re-register.
    7.31sec@203.3mph
    rafal's Avatar
    UK - PL
    can be as you wrote............i had ones same situation and after few attempts all went ok
    need help
    who will help?
    Dec 2015
    Portugal
    Screenshot_2019-12-03-08-42-39-212_com.xhorse.assembly.jpgScreenshot_2019-12-03-08-42-53-232_com.xhorse.assembly(1).jpg
    Quote Originally Posted by rafal View Post
    as the illegal)
    I don't have consult neither x431.
    Can you explain what consists the process of C/U initialization?
    The key to program must be I-key or could be a separate pcf?
    On the I-key, it's a separate pcf. But I don't know if I-key keyless function is connected with transponder, like on PSA remotes.
    Annex is the pages of virgin I-key.
    Dec 2015
    Portugal
    as the illegal)
    I try to make the C/U initialization with x-431, but still don't start the car.
    I couldn't clear DTC P1610 and P1615 after diagnosis.
    Only way I could clear DTC was after key programing sequence don't try start the car. Then I could clear DTC. Then y make C/U initialization,and key programming again, but no success.
    On key programming, after programming transponder, it should registrate I-key function, but never could registrate, always error.
    Just one question, when u make the C /U initialization, you program again just the exist I-key or a new one? Do you know if is possible to program just a spare pcf7936?
    busaman's Avatar
    suffolk uk
    ok i have fixed a broken switch on the ign barrel now all ECU,S are de registered no keys stored the only fault is in the engine ecu p0611 and p1612 the backup via bedm was re-written when i try to register the key it goes through the process at the end it says ( registration impossible check the vehicle is in the following status and then touch retry ign on .. intelligent key is inside the vehicle and button of the intelligent key is pressed) it detects the key if i look into stored keys there are none but a key shows up as unregitered and active when the button is pressed...
    7.31sec@203.3mph
  10. #9
    Dec 2015
    Portugal
    The only solution was take car to Nissan dealer.
    I don't know what they do to the car, but suppose it was just key reprogramming with Consult.
    Old key and new key works now, so there wasn't key problem.
    Maybe just Consult can reprogram this I-key.
  11. #10
    rafal's Avatar
    UK - PL
    as i told you in post #3..............
    need help
    who will help?
  12. #11
    Dec 2015
    Portugal
    But I try with x-431 but I couldn't make the C/U initialization.
    Or I make some wrong step, or just Consult can do the job.
  13. #12
    Meat-Head's Avatar
    DRIVEL MODE:-
    make sure drivers door open and closed when ignition off.
    just you don’t get rid of key in chime/acc power until door open
    DRIVEL MODE OFF:-
  14. The Following 2 Users Say Thank You to Meat-Head For This Useful Post:
    Faraday (17th September, 2020), rafal (14th February, 2020)
  15. #13
    Oct 2012
    I have the same problem. It is impossible to add the keys, i.e. it is adding but it does not remember, the diode does not flash but goes out. The errors are also the same 1610,1612,1615. The dealer spreads his hands, says that the only option is to replace everything in the car. They claim that the consult does not program keys on-line. It is strange that it sometimes starts with a glowing immo indicator. Someone will help?
  16. #14
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by tom a4 View Post
    Just reprogram key with consult and you are done because other tools doesn't program correctly keys
    Sent from my 5033F using Tapatalk
  17. #15
    May 2017
    Default qasqai programing key x431 read pin t300 programing go usa opsen 4 remuve 3 amp fuse
    Quote Originally Posted by ASCM View Post
    after put beck fuze 100% vorck on 2008
