Results 1 to 10 of 10
    Default Renault scenic 3 handbrake fault
    2010 reg.mk3. Got a problem.keeps coming up on dash .handbrake fault. Handbrake still works perfect. Diag code coming up is dtc50c649. This will delete for a day or so then comes back on. Anyone help with this fault please
    Meat-Head's Avatar
    Busy eating a banna
    tty editing them numbers. Eg uc064. B50c6. Etc
    betrer than cleaning a toilet
    Jan 2020
    Hi Radio solutions, for this fault code I would suggest to volt drop the power supply/earth/check connections and if correct and fault returns you will need to replace the park brake control unit.
    Apr 2016
    deutschland
    hi,for this error code i have replace park brake control unit and error code was gone.
  5. The Following User Says Thank You to ppr27 For This Useful Post:
    rideon (17th January, 2020)
    Got a fault on 2 x scenic 3 ,for handbrake. Fault is dtc50c449. Can anyone help with this fault please.
    Meat-Head's Avatar
    1) use different computer
    2) any other w/l on
    3) ADVERTISING. https://www.launchtech.co.uk/support...tc-codes-list/
    see if any take your fancy like “pad wear”
    4) doubt it, check tyre size and pressure
  8. The Following User Says Thank You to Meat-Head For This Useful Post:
    radiosolutions (18th November, 2020)
  9. #7
    2) any other w/l on
    Just a update. Wiring plug corroded on passenger side. Also for other fault.handbrake module has to be fixed into position or you get this fault. Thanks for help
  10. #8
    Meat-Head's Avatar
    Excatly where rotten plug?
  11. #9
    rafal's Avatar
    UK - PL
    in scenic III are 3 places where wirings are corroded - always same
    need help
    now my goal is to buy xp-005
    who will help?
  12. The Following User Says Thank You to rafal For This Useful Post:
    Meat-Head (11th November, 2020)
  13. #10
    passenger front by left foot behind panel. thanks
  14. The Following User Says Thank You to radiosolutions For This Useful Post:
    Meat-Head (18th November, 2020)
