    sdnatlst's Avatar
    Aug 2011
    England
    Default isuzu trooper 1998 all key lost
    hi all, i cant find any info on this at all 1998 isuzu trooper
    can anyone help with
    -key blade
    -TP type
    -how to retrieve pin and code new keys? remove immo box any idea where to read eeprom?
    thanks!
    Tools owned -
    ray-ray's Avatar
    Grey immo. Box above the gas pedal with “GM” marking on the box. The target chip 93c46 read it in 16bit mode pin# (4digits) the transponder chip is a magamos iD13
  3. The Following User Says Thank You to ray-ray For This Useful Post:
    sdnatlst (12th January, 2020)
    smokey08's Avatar
    Essex, UK
    What engine? 3.0 or 3.1? I done a 3.1 a few weeks ago. Blade was a GM15, I picked and decoded it with the MIT8 lishi and chip was 4C. Immobox was between glovebox and radio (UK RHD) with a 93lc66 dip eeprom. I programmed chip with Opel card in my tech2 and choose monteray. Isuzu card was useless on this car as year was too early.
    Sent from my Pixel 3 using Tapatalk
  5. The Following 3 Users Say Thank You to smokey08 For This Useful Post:
    Meat-Head (30th January, 2020), p1et (13th January, 2020), sdnatlst (12th January, 2020)
  6. #4
    sdnatlst's Avatar
    Aug 2011
    England
    It's a 3.1 ,
    So you decoded with MIT8 , do I need GM15 blade or does mit8 work?
    Any other China tool will program TP you think?
    I don't have tech2
    Tools owned -
    smokey08's Avatar
    Essex, UK
    MIT8 blade should work ok. Have a look through your programmers and see if any list Opel Monterey or you could add a 4c data straight to the 93lc66. Pincode is in plain text and obvious once you read the eeprom. I desoldered and socketed the eeprom as I was unsure if it would read in circuit and didn't want to corrupt it.
  8. The Following User Says Thank You to smokey08 For This Useful Post:
  9. #6
    sdnatlst's Avatar
    Aug 2011
    England
    Perfect appreciate the help!
    Tools owned -
  10. The Following User Says Thank You to sdnatlst For This Useful Post:
    smokey08 (12th January, 2020)
