Results 1 to 11 of 11
    super jumbe's Avatar
    Livingstone
    Default VOLVO V50 2008 remote programming instruction.
    Lads got a customer he replaced new remote battery now the remote stopped working any idea is there a manual syncro or by obd tool.
    Aug 2015
    after replace battery remote should work as previously.
  3. The Following User Says Thank You to kaponne For This Useful Post:
    super jumbe (16th January, 2020)
    drugowaz's Avatar
    Mar 2015
    Lithuania
    This remote programs only once when new with barcode. Or remote broken or problem in car
  5. The Following User Says Thank You to drugowaz For This Useful Post:
  6. #4
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by super jumbe View Post
    i was replaced a broken transmitter ic after that the remote still not working but according my testers all ok.
    My solution: Close all dors (trunk too) Put in the key into the slot, wait till the ESL released and keep pressed the unlock button a few sec. Test it. if not working rotate to ACC (don't start the car) and again
  7. The Following User Says Thank You to jodge For This Useful Post:
  8. #5
    p1et's Avatar
    Oct 2013
    Following this thread as seen multiple times before it lost sync after battery change. I heard also they just like to fail, even if they send RF signal they stops working but what a coinsidence would be to make it happen multiple times just after battery change...
  9. The Following User Says Thank You to p1et For This Useful Post:
  10. #6
    Meat-Head's Avatar
    OFF TOPIC:-
    had a vulva toed in non start, read on some herbal tea sharing website, lock unlock 4 times
    then it started.
    ON TOPICS
    TRUED tge key in tge door few times or cycle battery on car
  11. The Following User Says Thank You to Meat-Head For This Useful Post:
  12. #7
    Livingstone
    Thank you all I let it go been in bed with flue.
  13. The Following User Says Thank You to super jumbe For This Useful Post:
    Meat-Head (16th January, 2020)
  14. #8
    Meat-Head's Avatar
    bed with flue.
    Is that the flue off a gas fire or gas boiler
  15. #9
    mexanico1971's Avatar
    portugal
    My work is my life ART TECH GARAGE
  16. The Following User Says Thank You to mexanico1971 For This Useful Post:
    igorr (17th January, 2020)
  17. #10
    Jul 2015
    More correct is to say that remotes is alredy programmed from manufacturers, you just add id and crypto key to cem.
  18. The Following User Says Thank You to oskars268 For This Useful Post:
    Weasel3 (21st October, 2022)
  19. #11
    Sep 2021
    Quote Originally Posted by oskars268 View Post
    Bardziej poprawne jest stwierdzenie, że piloty są alredy zaprogramowane od producentów, wystarczy dodać identyfikator i klucz kryptograficzny do cem.
    Hello friend. I have similar problem. I have Volvo C30 with AKL situation. I add transponder on file. Car start, but I don't know how add remote. Autel and lonsdor shows comunication error in add key option. It is possible add remote on file? I have 24digit code from box. I have OEM new key
