hi, i am sorry not to post a solution to your problem, but i want to say i have a 2002 renault clio quickshift, and it has exactly the same problem as yours, when i move the gear lever up to select 1, the 1 light starts to flash on the dash and then goes back to N, the car doesn't move anywhere, also, when i select 1, the engine doesn't rev up, it almost wants to die if i press the accelerator pedal, and as soon as it goes back to N, the engine revs up fine again.
i was told it could be a problem with the multifunction switch, the resistance must be set to 0 at the terminals, i will check that tomorrow and post here if anything new,useful.
