Results 1 to 10 of 10
    WALES
    Default FVDI 2014 with "ERROR 5"
    HI all, I have an FVDI and most times I get "ERROR 5" when I select a car make.
    If I reinstall the software it works once then next time I get "ERROR 5" again...
    Any ideas how to fix this? I'm using Windows10, NO other option is available so please don't say XP etc....
    wbr
    rafal's Avatar
    UK - PL
    try add drivers manually and also set to latency 1
    need help
    now my goal is to buy xp-005
    who will help?
  3. The Following User Says Thank You to rafal For This Useful Post:
    shooting (19th January, 2020)
    WALES
    Quote Originally Posted by rafal View Post
    Latency is already 1
    wbr
    WALES
    Also on Porsche and Volvo I get "ERROR 3" .. what error is this?
    wbr
    rafal's Avatar
    UK - PL
    fvdi 2014 has a lots of problem with drivers and also doing some collision with others drivers...............
    the best way to buy other ( used ) notebook with win7 and install only fvdi ( i did like this )
    need help
    who will help?
  7. The Following 2 Users Say Thank You to rafal For This Useful Post:
    Andreastech81 (20th January, 2020), shooting (19th January, 2020)
  8. #6
    make sure you use twin usb cable which came with fvdi
  9. #7
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by fifii69 View Post
    and you think that it not work with other usb cable...
    in my case it was opposite...
    cable delivered from Shenzen, was sooooooo good quality that it even not worked one minute...
    used other cable and it worked...
  10. #8
    Quote Originally Posted by figani View Post
    yes that's what I think because twin cable supply more current but depend laptop USB performance , I had same problem before when I used single usb cable
  11. #9
    Dec 2018
    Budapest
    Can somebody help me in this problem? Try 2 Cara and same results.
  12. #10
    Jun 2017
    US
    installed on windows xp vm, no problems except for when trying to detect programmer, usually skip first instance. sometimes have to restart exe about 5 times.
  13. The Following User Says Thank You to darknezz19 For This Useful Post:
    dominic24 (18th January, 2022)
