Results 1 to 2 of 2
    Feb 2017
    Unhappy Peug 307 2002 bsi or ecu issues... A/C VSS OIL
    hi everyone
    i have a 307 with Sylea BSI, bsi was bought in scrapyard very cheap and i install in the car perfect, i make a immo off to the MM48P so the car starts perfect... BUT, no speedo or oil lamp and no air conditioned... plug my pp2000 and in BSI have 3 errors
    1 refigeration pressure information. incorrect value received
    2 speed information. incorrect value received
    3 oil pressure. incorrect value received.
    i change the speed sensor (VSS) and the oil pressure sensor aaand charge my A/C coolant for new ones. the truth is i can live with no speed sensor or oil sensor but with 38º of pure sun love i really feel desperate about A/C...
    i tested the compressor clutch via 12v at pink wire and works fine, air is cool and delicious, so i tested via pp2000 with engine off in BSI tests and clutch works for 1 second so is not a phisical failure (with engine on the test fail and says that is imposible to activate)... SO the question is:
    what is the best aproach to solve de A/C system?... i remember in my old nissan platina aka clio after apply immo off and cut 58 the A/C system stop to work so maybe IAWMM48P suffer for the same? its just my theory...
    thanks in advance masters and thanks for all your help.
    Feb 2017
    I think my problem is a bad immo off file... Anyone know a good file with a/c working for that ecu?
