Results 1 to 11 of 11
    Sep 2019
    Default FEM repair needed
    Hello i have 2014 3 series cas ID 8217012811. I am doing AKL for it. i read the coding and eep using vvdi 2 and orange 5 and when went to restore the coding, it is giving error 7F 10 12 (target unit doesnt respond or response err command). I tried writing the original eep back again but err persists. any suggestions what went wrong and how to fix it?
    Nov 2018
    GB
    Hi dear,
    I have FEM BDC plus device that can restore the FEM or BDC flash then you can write the coding and theeeprom, it is very good, I bought it from Simon touch it's not that much expensive I think it was for 600 euro
    Sep 2019
    thank you for your reply. On the same note, do you think its the flash which got corrupted?
    Nov 2018
    GB
    Yes, the FEM flash was damaged that's why you can write the coding.
    sdnatlst's Avatar
    Aug 2011
    England
    link for device?
    Tools owned -
    Nov 2018
    GB
  7. The Following User Says Thank You to khoulioking For This Useful Post:
    sdnatlst (31st January, 2020)
    ghostrider72's Avatar
    Jul 2012
    UK
    Quote Originally Posted by sdnatlst View Post
    link for device?
    Its just ACDP device with fem option. Don’t think it can restore flash/eeprom if no backup on it.
  9. The Following User Says Thank You to ghostrider72 For This Useful Post:
  10. #8
    sdnatlst's Avatar
    Aug 2011
    England
    Yes i already got that acdp and module, i guess need to find FLASH of same Part no. FEM and write it back ?
    Tools owned -
  11. #9
    Sep 2019
    i do have original eeprom and coding saved from fem. Do you think this tool can restore the Flash so i can upload coding and eeprom? or any tool capable of doing it?
  12. #10
    Jul 2012
    UK
    Vvdi Prog can do that as well
  13. #11
    Nov 2018
    GB
    Yes I am 100% sure that the ACDP can do it.
