Results 1 to 15 of 24
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Default CITROEN C2 BSI PIN CODE
    can you please give me the pin from that dump?
    it's from c2 bsi 95160
    i get the E605 but is wrong...
    Thank you...
    originalOK95160.zip
    stoyanov's Avatar
    42 75 6C 67 61 72 69 61
    Can't see VIN in this dump,maybe it's corrupted.Read engine ecu eeprom for pin code.
  3. The Following User Says Thank You to stoyanov For This Useful Post:
    Panathaole (30th January, 2020)
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by stoyanov View Post
    hi thank's
    it is strange because i had change the mileage in that dump with carprog, and bsi works fine(have a long time ago...)
    rafal's Avatar
    UK - PL
    test E605 or reverse
    need help
    now my goal is to buy xp-005
    who will help?
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by rafal View Post
    Thanks rafal...
    i had try both....
    0 or O not accepted...
    maybe i have wrong dump.... it's an old one stored in my pc... i try to read again the eeprom... thanks...
    Feb 2017
    E605 pin code
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    pincode is 5065 or 6550
    rafal's Avatar
    UK - PL
    Quote Originally Posted by jomberykaso View Post
    i am not sure my friend...............eeprom is bad readed ( a lot of info missing )
    need help
    who will help?
  10. The Following User Says Thank You to rafal For This Useful Post:
  11. #9
    Sep 2013
    my pincode is good my friend....
    information missing from line 0200 to 07F0 is history reseted
    mileage is 199755 kms (0B 85 E1 inverted E1 85 0B xor FF FF FF = 1E 7A F4 to Dec 1997556/10= 199755,6)
  12. The Following User Says Thank You to jomberykaso For This Useful Post:
  13. #10
    kiszka's Avatar
    Dear friend, your pin is bad
    pin is 506E or E605 on 1000000%
    Quote Originally Posted by Panathaole View Post
    Thanks rafal...
    i had try both....
    0 or O not accepted... is 100%
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  14. The Following 3 Users Say Thank You to kiszka For This Useful Post:
    jomberykaso (30th January, 2020), Panathaole (30th January, 2020), rafal (30th January, 2020)
  15. #11
    Sep 2013
    Im going to try to figure out it manually again....i want to know how it changes from 0 to E, my script show me the same code as you posted but I always like to check manually all my editions
  16. The Following 2 Users Say Thank You to jomberykaso For This Useful Post:
  17. #12
    rafal's Avatar
    UK - PL
    2nd picture more clear
    need help
    who will help?
  18. #13
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Pin code in this dump is E605, I give it to the guy in the yard and it used to an other similar car....
  19. #14
    rafal's Avatar
    UK - PL
    now you can see how by this thread you made a lot of trouble's
    need help
    who will help?
  20. The Following User Says Thank You to rafal For This Useful Post:
  21. #15
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    I apologize........
