    spiridonas's Avatar
    Default Renault Modus Power steering fault-DF002
    Hello
    Can anyone help me with renault Modus steering error codes DF002 (C1608), eeprom 24C16.
    Sterring
    TRW
    8200 307 154--A
    Thanks you very much
    Warsaw
    please virginize or reprog power stering
  3. The Following 4 Users Say Thank You to scenpo For This Useful Post:
    faza952 (10th May, 2024), marsete (7th September, 2023), pawelelectro (13th September, 2024), spiridonas (3rd February, 2020)
    Jan 2019
    hi friend
    try the file think must be good
    Pass in PM
    Oct 2018
    spiridonas
    hi collegue 100% solution, clear df002 code and clear immo code write eeprom and crc repaired ok
    <Clear IMMO Code> - Clears immobilizer code from PAS control module.
    New immobilizer code will be transfered from UCH to PAS
    control module on the first ignition OFF/ON cycle.
  6. The Following 3 Users Say Thank You to tothzsolt For This Useful Post:
    immokill (3rd February, 2020), rimljan (17th March, 2021), spiridonas (3rd February, 2020)
    immokill's Avatar
    Jun 2009
    UNIVERSE
    I use Reno Link or Xtool via OBD . But this solution works 100% also!
    Here to HELP!
  8. #6
    Fec001's Avatar
    Default Dump
    Can someone repair my dump please?
    It"s from Megane Scenic: DF002
