Results 1 to 10 of 10
    everywhere
    Default pcm flash and guardiant drivers
    Hello
    i bought pcmflash dongle and it is not working. i had installed prgoram pcm flash and guardant drivers on widnows 10. And it is not working. i have pop up "guardant dongle not found. make sure that guardian dongle is connected to the computer and the latest guardian driver is installed (49/50). anybody knows what could be wrong? i tried on second laptop with windows 7 also and the same problem.
    I also tried "run as administrator" etc
    What i have to do? dongle is bad working? In device manager in windows guarian dongle is exsits and drivers are installed correctly.
    Anybody can help to solve this issue?
    Best regards
    everywhere
    problem solved supplier send me txt key for it. sorry for thread, please delete it :-)
    Newbie koyzinho's Avatar
    Sep 2018
    Brazil
    Quote Originally Posted by piemot View Post
    how this txt works? is it a txt file that you paste in some specific folder??
    I have the same issue here and I am waiting for supplier to answer...
  4. The Following 2 Users Say Thank You to koyzinho For This Useful Post:
    Fogz (2nd February, 2022), mecafrigo (7th April, 2022)
    Aug 2016
    Can you help me? I have the same problem
  6. The Following User Says Thank You to Swiatek For This Useful Post:
    canozar (25th April, 2024)
    Feb 2023
    hi i have the same problem as you with guardant usb dongle can you help me?
  8. #6
    marsete's Avatar
    Oct 2010
    SPAIN
    Hello friends...test this driver for me runs perfect.Regards
  9. The Following 23 Users Say Thank You to marsete For This Useful Post:
    21Leonardo (8th June, 2023), Armando20 (6th May, 2023), autosoftbrasil (1st December, 2024), Bahar (20th January, 2025), boxsport (28th March, 2024), canozar (25th April, 2024), Col19 (27th February, 2025), daniersms (19th March, 2025), devvil (30th May, 2023), dorcky (7th March, 2025), eagleone-two (26th March, 2024), ferval (6th October, 2024), Greyh666 (18th May, 2024), hmagga (20th May, 2024), kaziukas1958 (2nd April, 2025), keymaker.gr (14th December, 2023), lsdlsd88 (27th August, 2024), marquicarpower (6th November, 2024), Rembrandt (25th March, 2025), seal777 (1st March, 2025), Shushp (29th November, 2024)
  10. #7
    Oct 2024
    Thumbs up
    Quote Originally Posted by marsete View Post
    thank you. I have problem too.
  11. #8
    Jan 2025
    well I've hope It will work
  12. #9
    Jan 2024
    Default thanks alot
    Quote Originally Posted by bartekkk View Post
  13. #10
    Mar 2025
    Thanck you I'll try
