Results 1 to 15 of 16
Thread: popcorn bmw e46
    Sep 2015
    Default popcorn bmw e46
    hello can someone help me make popcorn file 4,500rpm
    bmw e46 320BMW 320D 150HP 0281010565 1037361811 EDC16C1
  2. The Following User Says Thank You to amlop For This Useful Post:
    werte (3rd February, 2021)
  3. #2
    chrisimerk's Avatar
    Dec 2018
    England
    Quote Originally Posted by amlop View Post
    here you go try and report
    pass in pm
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
  4. The Following 2 Users Say Thank You to chrisimerk For This Useful Post:
    amlop (10th February, 2020), werte (3rd February, 2021)
  5. #3
    Sep 2015
    it seems that it is a launch control someone can make me popcorn please thank you.
  6. #4
    Jun 2018
    Bulgariq
    Thanks and Reputation
    Pass-PM
    Test and Report
  7. The Following 2 Users Say Thank You to naskochipa For This Useful Post:
    amlop (11th February, 2020), werte (3rd February, 2021)
  8. #5
    Sep 2015
    send pass please.
  9. The Following User Says Thank You to amlop For This Useful Post:
  10. #6
    Sep 2015
    hello popcorn does the same thing as the first file circulating when you change gears the car runs out of turbo and then catches it again if it is a failure in the electronics of the clutch pedal sensor.
    can anyone fix that error? thanks.
  11. #7
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    i can make you launch control or popcorn if you not solved
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  12. The Following User Says Thank You to AVDigitale For This Useful Post:
  13. #8
    Jan 2020
    Quote Originally Posted by AVDigitale View Post
    How it is done on the 136 hp model with vp44 pump, is it via TL map ? there are 2 TL and 1 for limp mode
  14. The Following User Says Thank You to Javado For This Useful Post:
  15. #9
    Sep 2015
    I want to make popcorn like this video.
    thanks.
    https://www.youtube.com/watch?v=r-MHakA7N7s
  16. #10
    Sep 2015
    thanks.
    Hello someone who knows how to make popcorn I have no solution with anyone someone who has experience please thank you.
  17. The Following User Says Thank You to amlop For This Useful Post:
  18. #11
    Feb 2020
    You will make LC using the first DW map. First DW map limits IQ when the car is stationary.
  19. #12
    Feb 2020
    Quote Originally Posted by Javado View Post
  20. The Following User Says Thank You to galusek29 For This Useful Post:
  21. #13
    Sep 2019
    Quote Originally Posted by galusek29 View Post
    Are you sure man? Tested? There aren't two maps, because of manual and automatic?
    What about torque maps there are 2 and 1 limp and rpms aren't the same in upper 2-maps so.. there is maybe something like in EDC16CP34 upper and lower limit of torque by atmo pressure or boost achived?!
  22. #14
    Mar 2017
    Portugal
    u can use single value near gear torque limiters
  23. #15
    Jan 2021
    hello
    you can stage 1 and popcorn at 4.500rpm
    edc16c31
    sw1037361811
    hw0281010565
    HelloyHellstage1 and popcorn at 4,500rpmthanks
