Page 1 of 4 1234 LastLast
Results 1 to 15 of 54
Thread: W204 climate control
    43
    Default W204 climate control
    In last mounth i get 3 Mercedes w204 climate control dead.
    Anyone can help to repair this units?
    PSAcars's Avatar
    Oct 2015
    HOME
    610
    Hello to all. What do you mean dead? No power, no display, no control, no diag or.....? Open one, make real good photos of pcb front and back, post here and lets go.
    43
    No leds and the car fan run at maximum speed
    43
    Here are the Fotos
    PSAcars's Avatar
    Oct 2015
    HOME
    610
    Hello to all. Start by cheking main voltage on mcu after that 5v for suport ic's.
    43
    Yes i have i ressolder all and now i have ligths in bench mode +12 and GND but in car not work.
    I think the problem is the nxp ct9471 (i think its a Can chip) but i not found any information and spare chip to buy and test
    PSAcars's Avatar
    Oct 2015
    HOME
    610
    Hello to all. Please make good picture of this ic.
    PSAcars's Avatar
    Oct 2015
    HOME
    610
    Hello to all. If we are talking of chip under big capacitor I think it is TLE9471ES.
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    228
    hello, I also have a car with a climate problem in the workshop !!
    don't turn it on !! In diagnosis does not respond! controlled with wiring diagram all ok, 12v GND and CAN 60ohm !!
    I saw on eBay that it will be repaired with 30Euro !!
    you have information
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
    PSAcars's Avatar
    Oct 2015
    HOME
    610
    Hello to all. No I dont have any info, we here started repair in forum but mffa stopped writing. If you want we can help , but you will have to be activ.
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    228
    Hi , this is the problem and the component to be replaced.
    https://www.ebay.com/itm/1pcs-UJA106...-/123246454237
    this is my contribution.
    I ordered, but it takes a long time, for delivery (Corona Virus permitting)
  12. The Following 2 Users Say Thank You to centrohifi For This Useful Post:
    amstel7 (4th September, 2024), PSAcars (26th March, 2020)
  13. #12
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    228
    I have solution for climate problem!
    I have solution for climate problem! tested on A2049005805
    to work
  14. The Following User Says Thank You to centrohifi For This Useful Post:
    KayaBalkan (20th September, 2024)
  15. #13
    PSAcars's Avatar
    Oct 2015
    HOME
    610
    Hello to all. And the solution is ........ ?
  16. #14
    Meat-Head's Avatar
    8,884
    Other idea, spray entire board with uv ink, and light clear coat, send away, open up use uv light see what changed
  17. The Following User Says Thank You to Meat-Head For This Useful Post:
    centrohifi (9th May, 2020)
  18. #15
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    228
    Another idea, put a fan, cockpit
  19. The Following User Says Thank You to centrohifi For This Useful Post:
    Meat-Head (9th May, 2020)
