Hope member who may have experience similar can chime in.
I have a permanent light on my dash showing ABS/ESP and a red brake icon on the speedometer side.
When the light first came on. I can clear it by pumping my brake, and it will go away for a few days, and came back again, and gone through the same cycle until it the 3 fault light will light up again the moment the car hill assist is activated. Hence, stop engine, pump, start, light goes away and works on and off when hill hold is activated when I am at a slop.
I have turn off hill assist, and tried disabling everything related to ABS/ESP etc.. but now the light stays on, but the car, brakes etc all works normally.
Running a scan using VCDS shows 01130 ABS Operation 008 - Implausible Signal
Tested all ABS/ESP wheel speed output and everything works normal.
For now. The lights will not turn on when I step and hold on to the brake pedal when I start the car, and the light will come on the moment I release the brake pedal.
I have gone through several forums, and some have suggested replacing the ABS module, which I am ready to do, but there are also those still having the problem even after replacing the ABS module.
There are suggestion of modifying the long coding adding some zero or to disable the ESP using long coding?
Hope member here can throw some lights.
Thanks for viewing.
